Old 06-28-2011, 03:17 PM
deadironrat deadironrat is offline
Stuck valve
I just purchased a 1984 Wagoneer that has been sitting for 10 years. Just before being left to rot it the engine was rebuilt. I can tell it was indeed rebuild because the paint on the block and heads is shiny and it holds good oil pressure even at hot idle. The problem is after getting it running quite well it developed a valve train tick under the passenger side valve cover. I pulled it off and found one of the push rods to be bent at a 45 degree angle. Unfortunately the valve is quite stuck. I can tap it down with a hammer but it will not recoil under the pressure of the spring. If I hit the cylinder head around it with an air hammer it will slowly rise back up all the way. I would like to know if anyone has any special voodoo tricks to freeing up this valve without pulling the head. I don't believe it is bent, probably just varnished from sitting for over a decade. Any opinions or ideas are greatly appreciated and will almost certainly be implemented (unless you tell me it's sol and I have to pull the head )
Thanks, Jacob
Jacob Z
1984 Jeep Grand Wagoneer, work in progress
Old 06-28-2011, 03:41 PM
FallonJeeper's Avatar
FallonJeeper FallonJeeper is offline
If it's stuck, it's stuck for a reason. It was enough to bend the push rod. You may spend a lot of time trying to free it up, only to have to do it again, or do damage to the piston, or have to pull the head anyway.
Save yourself the aggravation and pull the head. At least then you will know for sure.
Old 07-02-2011, 02:23 PM
After getting the head removed and torn down I found a bent exhaust valve (although oddly not the valve that was sticking). The trouble I'm having is in finding another, all the places that have them say that the soonest that could get them would be the end of next week for the beginning of the week after that. They are all having to order them straight from the sealed power, which means there is a decent chance it would actually take even longer to get one. Does anyone know of a company that might keep some valves in stock? I don't mind waiting a couple days for shipping, I just don't want to chance waiting a couple weeks for one valve.
Jacob Z
Old 07-02-2011, 02:27 PM
Chevelleguy's Avatar
Have you called Blaine's Motor Supply in Dallas?
http://www.blainesmotorsupply.com/
Old 07-02-2011, 02:44 PM
Tried, can't get them to answer the phone. Probably already gone for the 4th.
Jacob Z
Old 07-02-2011, 03:14 PM
Just in case anyone else is looking for AMC parts make sure you call NAPA. They actually still keep stuff in stock for us apparently. Including my elusive exhaust valve.
Jacob Z
Old 07-02-2011, 06:34 PM
djongeward's Avatar
djongeward djongeward is offline
That is impressive. Locally or special order?
89 Grandwagoneer, built 360, COMP cam set, port matched Edelbrock SP2P, 475 cfm Holley ORA, Thorleys, MSD6a, extra cooling and oiling.
76 Cherokee S Chief - rebuilt stock, Holley, Performer, MSD Dizzy.
89 GW parts waggy
Old 07-02-2011, 08:30 PM
Semi-local. They have 8 of them at their warehouse is Mesquite. I'm going to pick one up in the morning. Everyone is super special order, including Summit and Jegs.
I am extremely impressed with them for actually having them, I will be making a point of stopping at NAPA more now, some of their prices are cheaper as well.
Jacob Z
My 87 waggy heater valve is stuck Mark G General FSJ Tech 5 11-05-2009 12:14 AM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no hoax (Part 2) Wagoneerlover Fuel Injection 7 02-20-2008 12:30 PM
Power Valve Sealing Woes BenE General FSJ Tech 4 04-10-2007 09:06 PM
2100 Power Valve question caionneach General FSJ Tech 3 02-02-2007 06:00 PM
Correct Vapor Canister Purge Valve Operation Kevin718 General FSJ Tech 6 12-19-2004 03:46 PM
