Old 10-12-2010, 03:49 PM
megawisdumb's Avatar
megawisdumb megawisdumb is offline
Rear window trim
Anyone have any tips to remove the chrome rear window trim so I can blast and prime? Seems to be three pieces. Don't see any screws. 88GW
46 Willys
88 GW - stock 360
Old 10-12-2010, 04:00 PM
61Hawk 61Hawk is offline
Put a screwdriver in between the trim and body and gently pry it straight towards you. The clips holding it on pinch the seam.
Old 10-12-2010, 04:21 PM
Thanks 61Hawk..I figured that was the method but I've destroyed my share of stuff by not inquiring first.
46 Willys
88 GW - stock 360
Manual rear window issues... georgiajake General FSJ Discussion 2 05-31-2009 06:24 PM
Rear window assembly rusty eagle General FSJ Tech 1 04-01-2009 08:22 AM
rear window gooo... TimK General FSJ Tech 1 08-03-2007 06:41 AM
rear window switch diagnosis..help. rickauf General FSJ Tech 0 04-16-2007 09:44 AM
Rear Window Install -- what did you use to seal the window to the lower bracket rmorit01 General FSJ Tech 8 03-30-2007 05:37 PM
