Old 06-29-2011, 06:49 PM
deadironrat deadironrat is offline
AC condenser upgrade
I'm in the process of fixing the AC on my recently acquired Wagoneer and I noticed the condenser looks like an over sized transmission cooler (tube and fin type). It seems painfully inadequate compared to the condensers you see on newer vehicles. Being that I live in Texas and it gets quite hot I'm interested in if anyone has ever upgraded to a newer style condenser? It seems like it should be fairly straight forward and would probably provide a huge boost to your AC.
Has anyone ever done this? If so what vehicle did the donor condenser come out of? And did you see a drop in inside air temperature?
Jacob Z
1984 Jeep Grand Wagoneer, work in progress
Old 06-29-2011, 07:11 PM
What about upgrading to something like this?
http://cgi.ebay.com/ebaymotors/Universal-Parallel-Flow-Condenser-14-1-4-x-25-_W0QQcmdZViewItemQQhashZitem3a66cd7c5aQQitemZ25083 2845914QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries#ht_1786wt_1165
It would fit in the same spot as the stock condenser and the tubes are on the correct side. Everything I've looked at says that parallel are hands down superior to the old tube and fin the Jeep used. Any opinions?
Jacob Z
Old 06-29-2011, 09:22 PM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
You are only looking at half the system. The stock condenser is plenty adequate for the stock evaporator. For a higher capacity condenser to do you any good, you will have to increase the capacity of the evaporator or push more air through what you have.
Pete
'55 Willys Wagon, the original FSJ
Sitting on a '77 Cherokee frame, Dodge D60's
Isuzu 6BD1, NV4500, NP241
Old 06-29-2011, 09:29 PM
asphaltrockdweller's Avatar
Yeap!
What he said.
The condenser is fairly inexpensive in comparison to the evaporator.
I am doing an upgrade on my AC system, and found this out last week. To upgrade the evap, you are looking at 300-400 just for that.
Old 06-29-2011, 09:36 PM
I agree it's only half the system. But the stock evaporator doesn't seem quite as inadequate compared to the stock condenser. My thinking is if my evaporator isn't anywhere near freezing up (which mine isn't) then there is probably room for improvement.
Maybe it's just wishful thinking that this might help combat the Texas heat a little. But I certainly think it's worth a shot while I have the system apart.
Jacob Z
Old 06-29-2011, 09:37 PM
Has anyone had any luck flushing their AC systems? Or perhaps know why you can't flush an expansion valve??
Jacob Z
Old 06-29-2011, 09:41 PM
Are you going to change over to R134?
If so you should change that. Expansion valves are not that expensive anyways.
Old 06-29-2011, 09:45 PM
I already have a new one. I was just curious. I can understand not flushing an orifice tube but the expansion valve seems strange. Since as far as I know it has no filter inside of it.
Jacob Z
Old 06-29-2011, 09:56 PM
I stand corrected, there actually is a little metal screen down inside the expansion valve. At least there is in the old one I removed.
Jacob Z
Old 06-29-2011, 11:19 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
If you replaced the condenser and increased the system's efficency so that it suppied cooler refrigerant to the evaporator, it would overpower the inefficent evaporator and freeze it up. Then you have no cooling.
Old 06-30-2011, 03:20 AM
Thomas792's Avatar
Thomas792 Thomas792 is offline
Looking at that condenser I'm not sure it will work. I've been mocking up one based on dimensions on another site. The problem with the one in the link you provided is that the fitting is too close to the top. In my mock up I can put a 14 x 26 condenser in and the fittings are 2" from the top and bottom. At the top of the radiator support it dips down a bit on each side which is why the fitting 2" from the top will work well.
1974 J10 (401, Th400, Q-Trac, D44s, 28" tires)
Mrs Tickity - 1988 GW (360, 727, 229, D44s, 32" tires)
Old 06-30-2011, 07:47 AM
Autozone has evaporators for ~$100, Napa and O'Reily has them for ~$160. The condenser I can only seem to find at one place online for ~$300+
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-30-2011, 08:10 AM
Buy a universal one like i posted a link too. Far more efficient and less then $70.
Jacob Z
Old 06-30-2011, 10:47 AM
GW Fisherman's Avatar
GW Fisherman GW Fisherman is offline
How do you know what you already have is not adequate? The stock A/C works just fine as it was engineered. You would be throwing your money away unless you reengineered the whole thing. Your compressor only moves so much freon. Unless you replace everything matched to handle the volume of freon you can move through it, not gonna make a difference and may even hinder what you are after. That is why compressors, coils, metering devices, fan motors are matched for different tonnage.
Spend the money on insulating the roof.
2001 Subaru Outback 3.0 - Mamas assault vehicle
1989 Grand Wagoneer - DD and Boat Hauler
1985 Mercury 115hp inline 6 outboard
1989 Champion 184DCB - Bass boat
Old 06-30-2011, 10:53 AM
Just refurb the stock unit. They work just fine.
No real need to "upgrade" the condenser. I just bought a stock type replacement in '05 when I redid my system.
Even in a high desert setting mine pumps out ice cold
Depending on ambient temp, etc. I get 34*-44* out of the driver's side vent (furthest vent from the evap.)
Still running R-12, and it works great.
Old 06-30-2011, 11:26 AM
We are talking about the same company that couldn't put on body panels straight and thought steel oil pump gears in an aluminum housing was a good idea right? Im not trying to gain increased flow but rather increased cooling via a better designed condensed. It seems to me that upgrading a condenser is a lot like upgrading a radiator, it might not be necessary but i wouldn't think it could hurt anything.
Maybe Im just thinking about this all wrong. But while I've got it all apart i am going to give it a shot. If it gives me problems I'll just put the stock condensed back in.
Jacob Z
Universal Parallel Flow Condenser Installed (Warning- LONG and lots of pics!) Walt General FSJ Tech 10 06-16-2014 09:45 AM
Need for AC condenser paint Rod2 General FSJ Tech 1 08-16-2007 07:25 AM
AC Condenser Transmission Fluid Cooler 8379qtj10 General FSJ Tech 2 01-18-2007 12:27 PM
ac condenser and drier guy General FSJ Tech 2 07-05-2005 06:38 AM
GM HEI vs. Motorcraft/Duraspark ignitions (very long) Sycho15 General FSJ Tech 11 09-06-2002 07:46 AM
