Chevy axle swap on to WT Cherokee
  • Eugene 1
    • Feb 04, 2006
    • 1783
    hey guys i have 79WT chero. i kind of fell into these 82 Chevy Surburban Axles 3:08 gear etc..rear posi. has anyone swapped these in to an FSJ and is it hard to do? or should i say what is involved..my reasoning is my axles are mis matched and these are the right price FREEE anyhelp would be greatly appreciated
    ps I do not know what axles they are yet, I have not seen them, anybody have any ideas?
    JEEP
    2005 Ram 1500 HemI
  • Heep80
    • Apr 27, 2006
    • 260
    6 or 8 lug hubs?
    80 J-10 with 3in RC lift,1 in. shackles, buckshot M/T 33's. dual glasspack exhaust,eldobrock intake/carb/valve covers/aircleaner k&n, autometer tach, spare tire mount w/ fullsize spare,tool box, 40gal spare tank, grant steering wheel, rhino grill,DPA (Not installed Doug T's Headers, Hi lift jack, cobra cb,tie rods, & dual timing chain
    • Eugene 1
      • Feb 04, 2006
      • 1783
      6 lug and will that be passenger side drop?
      JEEP
      2005 Ram 1500 HemI
      • unclethumbtack
        • Aug 08, 2006
        • 365
        yes they are passenger drop. What is mismatched with your axles?
        Unclethumbtack
        81' Cherokee the turdburglar (off-road project)
        360 727 208 SOA 35" procomps
        Ramsey Winch
        77 J-10 258 QT (the restoration project)
        • Eugene 1
          • Feb 04, 2006
          • 1783
          I have Dana WT in the front AMC NT in the back im assuming the ratios are different too because the front Driveshaft was removed
          JEEP
          2005 Ram 1500 HemI
          • malodin
            • Sep 03, 2004
            • 1527
            front is a direct bolt in if its a 10b or 44(i dont know if its a different one) rear for me was a easy swap, just had to pull the leafsprings together and bounce it while it was loose a few times and it evened out pretty well. Some will say dont do that but to me we are talking less than 1/2" or so total difference between your fsj springs and the chevy spring perch(then again mine was a 3/4t maybe the 1/2t is a little narrower) all in all my 3/4t swap was supper easy.
            • malodin
              • Sep 03, 2004
              • 1527
              i just noticed you have a 79, is that a drivers drop front axle? if it is you would have to change t-cases to use the chevy front axle as i think 79 is drivers side drop.
              • #8
                they will bolt right up with minimal tweaking. go for it.
                Al
                • Eugene 1
                  • Feb 04, 2006
                  • 1783
                  no its pass drop...im going to take pics of the axles real quick be back in few
                  JEEP
                  2005 Ram 1500 HemI
                  • KaiserMan
                    I got the Willys....
                    • Jun 21, 2005
                    • 8702
                    The GM front is a bolt in, but it's SOA. Other, major issues involved with that.
                    The rear GM axle is a pos. 10b rears bring the s**k.
                    I'd say it would be eaiser to just get a matching ratio w/t rear for your Jeep.
                    1971 Gladiator
                    • Eugene 1
                      • Feb 04, 2006
                      • 1783
                      umm ok i have pics now
                      JEEP
                      2005 Ram 1500 HemI
                      • Eugene 1
                        • Feb 04, 2006
                        • 1783
                        what wrong with spring over axle i know nothing about this stuff
                        JEEP
                        2005 Ram 1500 HemI
                        • malodin
                          • Sep 03, 2004
                          • 1527
                          10b front and rear not the greatest, are you wheeling it much? if not then slap them in so its even and later down the line upgrade to the hd44/14b swap
                          • malodin
                            • Sep 03, 2004
                            • 1527
                            nothings wrong with SOA, though unless you get lift blocks or a rear shackle flip it gives the front at least 6" lift and nothing in the back. And you have to address a different steering solution, i.e cross over steering or full on high steer. if your going to leave it "stockish" i would say not to mess with those 2 axles and find your self a widetrack rear with the same gears as the front, do you know what your front gear ratio is?
                            • malodin
                              • Sep 03, 2004
                              • 1527
                              as well what makes you think you have a narrow track rear? rears are usually a little narrower than the fronts
