Old 09-13-2018, 09:52 AM
ls3waggy ls3waggy is offline
80 and older tail light seal?
Hey guys,
My tail light seals are pretty dried up and cracked, they're the "corner" style tail lights.
What do you guys typically seal these with?
Old 09-13-2018, 10:36 AM
Haven't done it on a FSJ but on others I've used silicone. Lay a bead on the part. Smooth it flat with an ice cube. Let it cure 24 hrs till firm. Assemble.
Edit:
PS, use black. It's not as UV sensitive as clear.
Old 09-13-2018, 10:38 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
tail light sealing
hello,
i have an 88 wagoneer,... different tail lights but,...
on the wagoneer and many other projects
i have used 3M Strip Caulk
comes in long blue box
caulk is sticky, black, and approx 1/4" or less around
lying on wax sheets
wet your hands to prevent it from sticking to you
you can shape it how you want and form a seal or gasket
if you want your housing or lens
to come off a little easier when you remove it
you can put vaseline or some grease on the part that contacts the strip caulk, and it will release easier, you can push the housing etc onto or into the strip caulk to seal it better.
hope this helps.
dave in NC
1976 HONCHO Fleetside
Tail Light Options? ERobertBurk General FSJ Discussion 6 08-07-2012 07:27 AM
tail light swap? wagonizzle General FSJ Tech 1 07-29-2012 01:39 PM
Late Weather Strip on Early Wags mtjeep General FSJ Tech 27 02-11-2012 01:28 PM
Older Pre 72 Truck and Waggy Door Seals. Pics and Proof - or Show & Tell. blakeusa General FSJ Tech 0 02-10-2012 08:55 PM
New seal; leak is worse caionneach General FSJ Tech 8 07-16-2007 11:38 AM
