It's been a while since I posted updates. The truck is rusting again. Paint is fading really bad. 4bt died last summer. Wrapping up the 12 valve swap. It runs like an animal. Should have done this swap the first time around.
I'll post up a video soon.
'68 M715, Cummins P-pump 5.9, NV4500, NP205, 14 bolt/Dana 60, 20x10 American Racing Mojave's w/12.50R20 Michelin XL's, relentless rust....
I think there are a handful of 4BT making that much power. And engine life at those power ranges is measured in hours, with absolutely no driveability.
Other than weight or size, it makes no sense doing that vs going with a 6BT, with can make that kind of power with relatively ease.
Got on I-95S at Newtown, PA, Exited at Woodhaven Road. This truck can move out in 5th gear with no trouble. Not bad for 6950lbs, and the aerodynamics of a br...
Man that thing is loud! Between the motor and the tires it probably sounds like a 747 coming down the freeway...totally awesome I hope I have one someday
Thanks for the compliments. The 4BT is gone, I sold it to someone in Harrisburg area. It was a good little engine while it lasted, but the 12 valve runs it's tail off. No more planning ahead for little elevation changes, just put it in 5th gear and put the hammer down.
