So here I am with another Wag (just can't help myself sometimes), I get to drive it for 1 day, it develops some issues (no surprise) and I get sent on temporary duty to North Carolina. Drat!!!
However, I am now on my way back home, 4 months later. Here is what I've got to deal with:
Cooling - I can't keep this running for more than about 30 minutes before my temp essentially takes a hard spike and over heats. It isn't gradual either, which to me is a little wierd, it will run cold for about 20-25 minutes, and then shoot to over 250 deg. Almost like my thermostat is culprit, though I am pretty sure I don't even have one in there, at least according to PO. Haven't had tme to dig into it yet. My plan is to run a jug of CLR through the Block (has been sitting for several years now) change thermostat, and possibly water pump at the same time and see what happens from there. Fan is working and the radiator doesn't appear to be leaking anyways.
Carb - It will not idle correctly and no amount of tweaking thus far will get it to perform correctly. I've checked my ignition system, it has a newly installed GM HEI conversion, timing is set at 8 deg, and when it does get gas it fires over and will run on high idle quite well. However, it will not kick down to low idle at all after the engine should be warm, and if put under a load at all will usually stumble and die. I am pretty sure that I am facing two issues with this. I am pretty sure that my carb is dirty and tarnished. I will be pulling it off, pulling it apart, cleaning and rebuilding it first thing when I get home in a day or so. Second is I am not sure that my timing is correct for HEI, but don't really know what it has to be at. Will research the archives, as I am sure I can find an answer there.
I hopefully will be able to have something to report soon. I am actually very excited about this, as it is an otherwise very clean G-Wag, and have been wanting to drive this for several months now. Wish me luck!
