Old 08-08-2020, 10:03 PM
spduffee's Avatar
spduffee spduffee is offline
AMC Pulleys
Hello All,
I have a pulley problem. On my 304 the crankshaft pulley had two chips missing on the inner wall(closest to the engine). I bought a used replacement and it looked different, but I figured it was OK. Everything was fine until I put the water pump pulley on, or tried to. The replacement turns out to be 1/4" bigger in diameter, and so won't fit (the w.p. pulley hits the c.s. pulley). Mine and the replacement are both for AMC 304's/360's.
Are there different matched sets, or something? My pulley is heavy, has a thick backplate and three dimples. The replacement is much lighter.
What gives?
Thank you,
Shawn
Old 08-09-2020, 06:16 AM
SC/397's Avatar
SC/397 SC/397 is offline
Yea there some different sets of pulleys but I can't remember which ones go with each other. Post up some pictures and the dimensions of your old one and I might have a good one to match -I have 2 buckets of them.
Old 08-09-2020, 09:44 AM
spduffee's Avatar
Here is a picture of what was on it before. It measures 6-3/4.
https://drive.google.com/file/d/1q-o...w?usp=drivesdk
Here is a picture of the one I bought as a replacement
https://drive.google.com/file/d/1q4J...w?usp=drivesdk
I'd prefer the one it had before, but would be grateful for either, as long as it fits. Please let me know if your bucket has one and how much you'd like to have for it.
Thank you very much!
Shawn
Old 08-09-2020, 10:33 AM
SC/397's Avatar
Do you have those pictures reversed?
I have never seen a cast one before. All of mine are stamped steel like the one with the steel tape on it.
Old 08-09-2020, 04:00 PM
spduffee's Avatar
Nope, I have not seen one either. The 360 had a stamped steel one, my CJ5 has a stamped steel one, too. This 304 supposedly came out of a CJ5. And when I search for a crankshaft pulley for a 304/360 both versions pop up.
If the stamped steel version is bigger, there must be different water pump pulley sizes, too. Time to start looking at various parts manuals, I guess....
Mismatched belt pulleys... Dr. Marneaus General FSJ Tech 15 02-24-2014 10:32 PM
Pulleys self-clearancing - What did I do?? turtlejoe General FSJ Tech 4 12-31-2011 01:33 PM
Pulleys for AMC 327 w/pics red mistress Fuel Injection 26 12-01-2007 10:07 PM
Fan Pulleys Loose 95pontiac General FSJ Tech 8 11-05-2003 08:48 AM
noisy engine pulleys JBurke General FSJ Tech 1 06-05-2002 07:07 AM
