Help with Throttle Body ports for Howell Kit
  • vanplumley
    • Jul 28, 2014
    • 17
    Ok guys, as always, I've tried to search everywhere and I'm sure one of you will explain it or link to another post and I'll feel stupid but here goes.
    The diagram Howell gave me has three ports on the front of the throttle body labeled J, A, and C.
    My problem is that on the front of my throttle body, J is blocked off on the left side (no hole, nothing nada, see pic)
    But there is a port on the right side labeled S. After poking around for pictures of TB's on the interwebs, it looks like there used to be two ports for manifold vacuum, Left manifold vaccum, and right manifold vacuum, so I'm assuming that I can just replace port J with port S? Which should go straight to the distributor, right?
    Thanks everybody
    Live in So-Cal
    1990 Grand Wagoneer 4 inch lift, 32" BFG's, Howell TBI EFI
    1986 Grand Wagoneer with - nothing, she's sittin on jackstands
  • vanplumley
    • Jul 28, 2014
    • 17
    So really, instead of being like J, A, C like this,
    I should just swap the order to C, A, S(instead of J)
    Right?
    Live in So-Cal
    • babywag
      • Jun 08, 2005
      • 10288
      yes
      • vanplumley
        • Jul 28, 2014
        • 17
        Tony the Babywag to the rescue as always. Everybody is beyond lucky to have you as a resource my man.
        Live in So-Cal
