Old 02-18-2021, 06:56 PM
caionneach's Avatar
caionneach caionneach is offline
Headlight wiring
Many already know this, but the link for the headlight wiring document is no longer working: http://www.tworock.com/mjd/jeep/wiring/wiring.html
I understand the creator of that document is no longer with us. May he rest in peace.
That link is still in the Tech Library section under electrical.
Does anyone know of this document and the write-up for upgrading the headlights? Any decent substitutes for SJ vehicles?
Thanks.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 02-19-2021, 12:05 PM
Thanks.
I wrote an article about the same topic - but it's for CJs, and shows the conversion on a CJ-6. May still help you. Once you understand the idea, you won't need a lot of coaching. http://earlycj5.com/xf_cj5/index.php...detail.142321/
You can use the internet archive ("wayback") to find sites that are gone: https://web.archive.org/web/20200212...ng/wiring.html The single relay conversion seems pointless to me, but to each his own.
Old 02-22-2021, 07:37 AM
caionneach's Avatar
Excellent
Thanks for that.
I found a copy of the file I had saved and emailed to myself for safekeeping.
I should find a way to post it to the tech library so that the document referenced remains available.
I believe this is the document Serehill stated was too complicated when its stated aim was simplicity, and his instructions were much less complicated.
1982 Cherokee
Old 02-25-2021, 09:32 PM
nograin's Avatar
nograin nograin is offline
I just took a look at the webarchived diagram. I agree with Tim.
Honestly I don't see what that accomplishes.
If the goal is a more direct power route to the headlights, then Rick's harness will do that. It just needs to be connected to the alternator output
Photos and diagram here http://www.ifsja.org/forums/vb/showthread.php?t=184659
Daniel Stern has a relay wiring diagram on his website (something like Daniel Stern Lighting). Its a little different. Closer to what made up for my Barracuda. Same type of power distribution as the SJs up through '85. So same thing, connect to alternator output for power.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
79 Headlight wiring plug issue CMorrow General FSJ Tech 11 12-14-2011 10:25 AM
CERAMIC H4 HI HEAT HEADLIGHT HEADLAMP LIGHT BULB WIRING HARNESS SOCKET PLUG PAIR Tin Medic General FSJ Discussion 2 11-30-2011 06:00 PM
Trailer wiring short Wagonforever General FSJ Tech 1 06-19-2008 07:23 PM
new wiring job (Interior of rig with pics!!) Wagoneerlover General FSJ Tech 21 05-14-2008 06:35 PM
