So I ran uptown last night for some smokes and a 6-pack, and on the way home my headlights quit working. I've been having headlight issues for several months now, but it usually consisted of only one or the other going out from time to time. When it first started happening I could usually get it back on by smacking it with my hand a time or two, but in the last month or so that hasn't worked.
Headlights are both good (tried them on another vehicle), so that left the harness and the switch as the possible problem areas. Cleaned all the grounds and plug sockets, applied fresh dielectric grease to all the sockets, still nada.
Since I wanted to upgrade to H4 headlights anyway I ordered Jared's harness (very nice BTW!). Unfortunately this didn't help any as it uses the current through the factory headlamp harness to activate the relays on the new harness. In other words, I got it installed this morning and still no headlights.
Pulled out the multimeter and started checking things. Started at the sockets on the new harness...no voltage. Then checked the sockets on the factory harness....no voltage there either. The only other things I know of inline between the harness and the power source are the switches.
So now for the questions. Is there a way to test the headlight switch to verify it's the culprit? Also, if the dash switch is bad will that prevent the high beams from working as well (I'm assuming it would).
And of course....the switch is a special order item at AutoZone. (insert several 4-letter words here)
