I have an 87 GW in Spinnaker Blue that I'm restoring.
I have been heavily researching whether to remove the wood trim and repaint it, or leave the trim on and mask it off. I cannot find a firm answer... I think i am going to leave it on and mask it off and repair (re-stick with adhesive) the portions of the trim that are peeling. I have heard (and seen) if you take it off, it will be wavy when reapplied. Is leaving it on and masking it the right choice or is there some issue that I could run into by doing so?
As for vinyl, mine is in good shape on one side, however the other is faded and peeling, so i will need to replace all of it. What manufacturer/source is closest to the original Di-Noc? I have heard the current Team Grand Wagoneer Marine Teak is closest, but the samples I received look a little shiny in comparison to OE Di-Noc. The Marine Teak 3M repro di-noc from metrorestyling.com is nice and flat, but not the same wood grain pattern and the color differs slightly. Which should I go with, or is there another supplier?
Has anyone else recently gone through with this? I know Gunnar's vinyl comparison is great (thank you Gunnar), but new products are always coming out. Looking forward to hearing some opinions.
