Hi All, since I'm ranting (at what I see in the magazines) I thought I would throw this out too. I've seen a few 4x4 type mags that show Z shaped steering arms to "correct" bumpsteer after a lift. They are usually captioned with a blurb about a staight arm is bad and causes bumpsteer. I feel that the Z arm is functionally the same as a straight arm. And that only by having the joint at the steering box nearly level with the joint at the knuckle will you control bumpsteer. What are your thoughts, are the rags just promoting advertisers at our expense? Dean.
'78 Wagoneer Limited
401/Q-trac W/low range
Stock for now.........
