Old 01-06-2021, 10:49 AM
The fusible links are in the engine compartment. A '77 only has one, between the battery and the Jeep. Connection to the battery is at the starter solenoid, where the (+) battery cable from the battery connects. They just look like wire. Suggest you don't worry about them unless you lose power to the Jeep.
Old 01-21-2021, 05:45 PM
Triumph215 Triumph215 is offline
Got it done, all seems to work great. Put some gas in and the gauge moved, temp gauge working too. Now if I could find my electrical surge...
1977 Wagoneer
1964 Triumph TR4
2009 BMW R1200 GS
Old 01-21-2021, 07:00 PM
Curly5759's Avatar
Curly5759 Curly5759 is offline
Have you tried disconnecting the alternator at the charge wire coming off the back and then running the engine? If the surge is gone, you know it is the alternator/regulator. If not, the problem lies elsewhere. Easy way to narrow the problem down.
77 Cherokee S 360/TH400/QT
Old 01-30-2021, 08:32 AM
nograin's Avatar
nograin nograin is offline
If you're going to do ^that ^ make sure the wire's ring terminal does not touch any ground.
Another thing you (Triumph) can do is reconnect the ammeter. (Disconnect the battery when doing this). In addition, have a voltmeter handy. Since this pulsing is happening at idle, a multimeter will work fine. Between the two meters you will have a pretty complete picture of what is happening.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
New Electrical Question '90 GW stonehengeheels General FSJ Tech 5 05-03-2012 06:30 PM
HELP, electrical question !!!!!!!!!!!!! LakeTahoeWagoneer General FSJ Tech 6 07-02-2011 12:07 AM
Is something wrong? - Electrical question srobertsfsj General FSJ Tech 13 11-09-2010 09:38 AM
electrical question? Heckofadeal General FSJ Tech 1 05-29-2008 03:06 AM
NP229 Electrical Switch Question chr1s General FSJ Tech 2 04-22-2004 11:21 AM
