Old 12-26-2020, 04:30 PM
posulli88's Avatar
posulli88 posulli88 is offline
What would cause sparking on outside of Sparkplug?
Just pulled a couple spark plugs to see how they were running. They looked good. I re installed and started the engine. Everything was running fine but I noticed one of my spark plugs was arching on the outside of the plug from the boot and grounding on the outside spark plug ground? What would cause this? I think its just one plug but I am going to check tonight when it is dark to see if others are doing the same.
My ignition set up is:
MSD distributor
MSD Super Conductor wires
MSD Coil
Old 12-26-2020, 05:31 PM
letank's Avatar
letank letank is offline
cracked boot... or bad plug... the silicone of the boot may have a split... been there... I thought it was the plug... but again putting my hand on the wiring I was shocked... as In Zapped...
Michel
Old 01-19-2021, 11:46 AM
posulli88's Avatar
Upon closer inspection the Exterior Spark Ceramic was cracked in two places. Must have had a damaged plug from the get go. Replaced it am good to go.
Old 01-19-2021, 12:21 PM
I'd be curious where you bought the plugs. I've heard of many issues with Amazon / Ebay type stuff due to the Chinese flooding the markets with counterfeit plugs. Very common with NGK and other more recent makes and models.
--Rob--
My build thread:
Old 01-19-2021, 12:22 PM
I'd be curious where you bought the plugs. I've heard of many issues with Amazon / Ebay type stuff due to the Chinese flooding the markets with cheap counterfeit knockoff plugs. Very common with NGK and other more recent makes and models.
--Rob--
My build thread:
Old 01-19-2021, 12:43 PM
posulli88's Avatar
Honestly I can remember where I got them but it would have either been summit or a local parts store. They are NGK FR5's...
Old 01-20-2021, 04:29 AM
All it takes is to drop the spark plug on the ground to make them crack, either by supplier, parts person or you. if I see them drop it I get different one and inspect all of them at the store.
Old 01-20-2021, 07:13 AM
Tanker Tanker is offline
I was going to say someone doesn't like you.They used a #2 pencil to draw a line from ground to tip.. Instant short.
Owner of Jakes FSJ Junkyard 91 Jeep Cherokee /2006 3500 Dodge AKA Babe the big blue puller
Hire the handicapped, they are fun watch!
Old 01-21-2021, 02:44 PM
Ive had this happen before, same issue, ceramic was cracked. Took me a bit to find it as it wasn't consistent.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 01-23-2021, 08:02 AM
Harrinad Harrinad is offline
Have you tried a diesel swap? Easiest way to fix this I can think of.
Old 01-23-2021, 09:05 AM
SJTD SJTD is offline
Not the easiest way but the best.
Sic friatur crustulum
What sparkplug do you use? 91blaze General FSJ Tech 28 08-19-2012 02:43 PM
MSD 6A isn't sparking... will e General FSJ Tech 3 11-01-2010 03:08 AM
tfi upgrade sparkplug gap? travisrda General FSJ Tech 9 02-08-2009 12:53 PM
Best sparkplug / best gap... aerocorey General FSJ Tech 32 12-28-2006 02:22 PM
SPARKING ISSUE Thecozmobile General FSJ Tech 5 09-23-2002 09:16 AM
