My casket is rusting off the bottom of my fuel tank and I was inspired by Wagoneerlover's 42 gallon burban tank install to put a tank in the spar tire area that I can't use now that I have 33s.
I originally wanted a 42 gallon and found a line on one from a friends blazer but it turned out to be a different model than the one wagoneerlover used and way too big. I also decided That I didn't like the idea of cutting into the frame either.
I hit up ebay and found several potentials but eventually decided on the 30 gal because it should share most the same stuff with the 42 other than size and therefore I could use the 42 gallon thread as a guide.
http://cgi.ebay.com/ebaymotors/FUEL-TANK-chevrolet-BLAZER-part-auto-SUV-94-93-92-1992-/150484308169?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A1994|Model%3ABlazer&hash=item23099050 c9
It also has the right dimensions to fit between the frame rails without cutting and is only 7/8s deeper than the 42. So it will hang lower but not by much. Probably just enough to look silly.
My first problem the hitch receiver that was in my jeep. Its the OEM 4 bolt design(I am assuming this because it is stamped jeep) the runs its bracers diagonally.
Since it doesn't hug the frame it was all up in my airspace I needed to put the tank up and clear the the exhaust and the rear shocks.
Luckily the 88 waggy I sold cutter had a different(maybe heaviear duty?) hitch receiver that hugged the frame and he let me keep it. I left it in AL when I moved so I had to have it shipped to me last week.
I installed it today after drill , and it was pretty easy because the holes were already drilled in the frame factory so it was a bolt on affair.
With that problem solved I got the girlfriend to take some pics and some measurements while I held the tank in place. Just to kinda get an Idea of how it will sit when done.
What we found was that the bottom of the tank will sit about 7 inches below the rear frame rail and will have about 16 inches ground clearance. I figure once the sending unit is installed it will probably end up closer to 15 inches. So not the greatest but I am not really planning on rock crawling so and the tank is metal so I think it may be ok. The intake hose won't take up much room because it is angled.
This is probably as far as I will move for a few weeks. I still need to get a sending unit and the stupid breather valves that cost like 20 bucks a piece and I am broke. I bought the sending unit for the same year blazer the tank came from a while back. The ad didn't say whether it was for the 30 gallon or not so hopefully it doesn't matter.
I am not sure that the blazer sending unit will work with the stock fuel gauge. I highly doubt it will but am keeping my fingers crossed. I may try to rig the old unit from the wagoneer tank but there is no way that it would fit. I am going to cross that bridge when it comes. I have other fish to fry like how I am going to run the straps and how/if I am going to get a skid plate in the mix.
Any how thought I would keep tabs on my progress here.
