I rebuilt my 2150 and it ran great for a couple days after rebuild but now the car won't run if has been sitting for a couple hours. It will run for a few seconds then die and not run again. It seems that the float is sticking in the closed position not allowing fuel into the bowel. If I beat on the carb with a screw driver or remove the airhorn it works fine.
There is also a high pitched sound comming from the carb that is only present sometimes and only on idle this has been there before the rebuild
I'm at my wits end. Please help
