Old 05-29-2013, 10:09 AM
BillyWagoneer's Avatar
BillyWagoneer BillyWagoneer is offline
anyone ever towed there fsj on a penske trailer?
i know they say your not supposed to because of the weight but the wheelbase is ok. but as far as going across weigh stations and being safe?
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
True Dual side pipes
TF 727 & np229
B&M Shift Kit
12 Bolt rear & D44 front
4.10's and ARB lockers
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-29-2013, 10:31 AM
So long as it fits onboard properly, properly secured and doesn't exceed the GWR that's on the trailer build tag or exceed the hitch capacity of the tow rig I can't see an issue at the scales. I've never had an issue with a properly sized U-haul or tool rental shop trailer in WA can't see where a Penski trailer would be any different. So long as you're playing by all the rules you should be good.
Old 05-29-2013, 10:50 AM
goldhammer's Avatar
Most states don't require U-Haul type trucks to go through scale stations. With Joe on it, as long as you don't exceed trailer weights should be good to go.
Art
ASE Master Collision Tech
Old 05-29-2013, 10:51 AM
CutterN55's Avatar
I played that game once... the money is better spent on a heavy duty tow-bar you can keep. I use the tow-bar a couple times a year.
I do long distance trips often though and trailer rentals cost a bunch.
My jeep is now too big for most rentals anyway.
I did once buy an old Big Tex tandem axle hauler and put new tires on it, used it, sold it and came up a hundred bucks or so.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 05-29-2013, 04:24 PM
svining's Avatar
svining svining is offline
Private citizen/Non-Commercial
I learned this while hauling my household goods around in the Service. You are not required to stop at weigh stations. Also, the rental companies post considerable weight capability much less for liability reasons. Like do not exceed 45MPH!
Be careful, don't take unnecessary risks, Can do!
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 05-29-2013, 07:59 PM
silvercert silvercert is offline
Towed mine behind a penski truck last September from tx to nc... used a towbar though. Removed bumper welded bumper brackets to a steelbar. Then welded towbar brackets to that. Was easier for removing later. Towed like a champ... no issue. Couldn't even tell it was back there. Just removed bother drive shafts.
Daniel
I have some good news and some bad news. The good news is that I always allow each student one free pass in my classes. The bad news is that you have now used yours for this class. Doug
Old 05-29-2013, 08:45 PM
guitarsail's Avatar
guitarsail guitarsail is offline
I towed my cherokee on the dual axle uhaul trailer behind a 26' pendle truck from Atlanta to Orlando going about 55 the whole way no problems at all.
Old 05-29-2013, 08:57 PM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
I just started working for uhaul and the trailers are rated for either 7000 or 7500 GVW, the trailer weigh around 2000lbs.
Pierce,
77 J10 360 4bbl, TH400, D20, HEI, Holley carb, Performer intake, Thumpr Cam, Hedman headers, dual exhaust, Auburn limited slip, hydroboost.
Old 05-29-2013, 09:43 PM
yeah i switched my reservation from penske to uhaul saved 80 bucks and there trailers can actually take the jeep. the penske trailer can only take 4000 punds. also going over the 80 from nevada to california there is a giant sign that says all rental trucks requierd to wiegh in
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-30-2013, 01:22 AM
I used one to tow my '83 J10, minus the front clip and motor/trans to Canada. It weeble/wobbled all over the place at 50 and often less so I took the back roads.
Old 05-30-2013, 06:17 AM
svining's Avatar
Too Bad!!
I used to make some good money moving myself on PCS's, never gave a thought to total weight. Even the biggest Penske's had posted GVW's way under the trucks rated capacity.
You sure they are not just looking for AG products. California is one regulated state!
Flashlight
Old 05-30-2013, 08:53 AM
Yes that is all there looking for but that weigh in station is notorius for being sticklers
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-30-2013, 08:58 AM
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-30-2013, 10:14 AM
svining's Avatar
Let us know what they check!
I remember that station from back in the 80's. They were even looking at household plants and ferns. But these days probably drugs, terrorist's etc.
They just asked and waived me through, I did have a car on a dolly too! I don't recall a scale but they had a shop and could tear you down to the chassis, if they wanted
Flashlight
Old 05-30-2013, 07:30 PM
Adam_Tinkerer Adam_Tinkerer is offline
I towed my '70 Suburban 365 miles on a U Haul trailer without problems. I may have -cough cough- accidentally listed it as a Blazer so the reservation would go through.
How the heck do the trailer relays work? (Schematic question) iroc86 Electrical 22 07-01-2015 10:32 AM
Expedition trailer build...pic heavy grand_wag_85 General FSJ Discussion 21 07-06-2012 04:09 PM
Hauling our Boy Scout trailer twmattox General FSJ Tech 17 01-27-2012 12:12 PM
OEM trailer wiring mystery dabear General FSJ Tech 10 02-13-2008 06:31 PM
Car Trailer to haul J4000 aerocorey General FSJ Discussion 7 07-01-2007 06:50 PM
