727 229 reverse bang
  • xGROMx
    • Jun 24, 2008
    • 129
    Ok, I've searched and searched with out finding the information I am looking for. The results I have found is symptoms of the 400-QT setup.
    85 Wagon with a 727 and 229, when putting it in reverse it bangs bad, and seems to be getting worse. I crawled under it the other day with the rear off the ground, while twisting the drive shaft you can head a bang (metal to metal) or clank and it seems to be coming from the front of the 229 right at the connection to the tail shaft. Now I see that the coupler on the 400 and QT is a common thing to wear and go. What about the 727 and 229? Coupler? Something inside of the 229?
    Drove it 15 miles on the beach today with no problems other than the reverse bang. Does not do it from reverse to drive, only when going into reverse from any gear.
    I want to fix it, but don't know where to start. I have never dropped a trans or xfer.
    [email protected]
    "A Truck is Only Powerful as its Driver"
    85 Waggon - SOA+Shackle Flip - OnBoardAir
  • BillyWagoneer
    • May 04, 2012
    • 715
    mine does the same thing, chain slack probably. drive it till it breaks!
    87 gwag
    De Smogged
    Promar Amc 360 Ci
    .60 Over
    Melling MTA-1 Cam
    MSD Multi Spark TFI
    Holley TA
    Performer Intake
    Hedmann Full Length
    True Dual side pipes
    TF 727 & np229
    B&M Shift Kit
    12 Bolt rear & D44 front
    4.10's and ARB lockers
    SOA & shackle flip
    33 12x5's
    Empty wallet
    • xGROMx
      • Jun 24, 2008
      • 129
      Chain slack, am I thinking diffrently on how the transfer case works or doesn't the chain turn the front drive shaft, I have the problem in 2 wheel and 4.
      [email protected]
      • aktrapper
        • Aug 29, 2008
        • 115
        U-joints
        Mine was doing the same thing and it turned out to be the axle u-joints. Check and replace and see what happens...
        Certified Novice Mechanic...
        89 Grand Wagoneer (AMC 360/TF727/NP229)
        A work in progress!
        • BillyWagoneer
          • May 04, 2012
          • 715
          IM no deliberating expert but IM pretty sure your chain is always going and there is another part that disengages the front end
          87 gwag
          De Smogged
          Promar Amc 360 Ci
          .60 Over
          Melling MTA-1 Cam
          MSD Multi Spark TFI
          Holley TA
          Performer Intake
          Hedmann Full Length
          TF 727 & np229
          B&M Shift Kit
          SOA & shackle flip
          33 12x5's
          Empty wallet
          • Dumpy
            • Jan 30, 2009
            • 2438
            This
            Justin
            '72 J2000 360 4bbl T18 D20
            • Billygoat
              • Mar 16, 2004
              • 2493
              Mine 727/229 bangs when you put it in reverse in 2wd, but not when in 4wd
              so pretty sure it is not the axle U joints - and my rear shaft joints are good too.
              The chain is the front drive, the rear is thru splines
              However the coupler that allows full time drive is in the thru section of the case (basically a limited slip differential) so I suspect there are issues with it that is creating the bang???
              I am in the run it until it breaks camp.
              • BillyWagoneer
                • May 04, 2012
                • 715
                If you read the original post, he jacked up the rear and turned the shaft. If you had a u joint on it's way out I think he would have noticed that.
                87 gwag
                De Smogged
                Promar Amc 360 Ci
                .60 Over
                Melling MTA-1 Cam
                MSD Multi Spark TFI
                Holley TA
                Performer Intake
                Hedmann Full Length
                TF 727 & np229
                B&M Shift Kit
                SOA & shackle flip
                33 12x5's
                Empty wallet
                • Miraphone186
                  • Sep 08, 2012
                  • 83
                  I've been having the same problem, it's weird...
                  1990 Grand Wagoneer DD
                  • xGROMx
                    • Jun 24, 2008
                    • 129
                    Thanks Billy, and yes its not u joints like ever other person posts on ths question and its not the rear end. As I say it seems to be coming from the front of the 229. Befor. Took it down I was hoping somen one else that had already would chime in. Im nt that fami lar with the 229 and 727 connection but it seems to sound just like the 400 and QT issue.
                    I hope not, that would m an. Would have to replace both. As for the chain, unless tye chain is driving the rear axl its not the problem.
                    [email protected]
                    • The Colonel
                      360 AMC
                      • Feb 21, 2010
                      • 2842
                      In 2WD mode the NP229 chain isn't under any load. I'd look more at u-joints or diff backlash.
                      • xGROMx
                        • Jun 24, 2008
                        • 129
                        Again already ruled out u joints a diff.
                        [email protected]
                        • BillyWagoneer
                          • May 04, 2012
                          • 715
                          87 gwag
                          De Smogged
                          Promar Amc 360 Ci
                          .60 Over
                          Melling MTA-1 Cam
                          MSD Multi Spark TFI
                          Holley TA
                          Performer Intake
                          Hedmann Full Length
                          TF 727 & np229
                          B&M Shift Kit
                          SOA & shackle flip
                          33 12x5's
                          Empty wallet
                          • addicted
                            Big Meanie
                            • Dec 11, 2004
                            • 4876
                            Take the drive shaft off and eliminate it and the rear diff from the equation. Sounds transfer and you'd be surprised when a diff has issues and it transfers through the hollow drive shaft.
                            Originally posted by Ristow
                            i bet it was Simon....
                            • #15
                              ^What he said^ It's either Ujoint (likely front) or the tcase yoke is cracked (I've killed 4)
                              I think (someone else can confirm) the front yoke is the same as rear so you could drop the front shaft out and "borrow" that yoke if the rear is cracked until you get another for the front (put the old rear yoke on the front to keep the oil in but leave the front driveshaft out till you get it)
                              Another possibility is the output bearing of the tcase is going bad.
