Old 08-18-2018, 07:40 PM
mwood65's Avatar
mwood65 mwood65 is offline
Wind deflector
I was wondering if the wind deflector that is on the top rear of some FSJ's actually does anything worthwhile?
Can you run with the rear window down without exhaust coming in or is it more an aerodynamic thing?
If it helps air flow and keeps the exhaust out with the rear window down then I need to find one....
Old 08-18-2018, 08:00 PM
It's supposed to keep the window clear from light dust or light powdery snow kicked up from traveling. IMHO a pretty useless doodad and certainly not worth drilling holes in your roof for.
Old 08-19-2018, 03:17 PM
Don S's Avatar
Don S Don S is offline
Geriatric Doctor of FSJs
I liked these deflectors. My jerry can was vented and I never had any kind of fumes. Driving across the well maintained northern Colorado dirt roads at speeds of 40 to 60 mph they kept the rear glass clean enough than I could keep my following friend in view.
on the other hand I kept the rear glass closed all the time.. Don S..
Sold our 1976 Wagoneer 406, MC4300, TH400, QT, TruTrac, 2" lift, 31x10.50s, duel Optimas,
It’s took us over 161 Colorado Mountain Passes, 3 Jeep Jamboree USAs & 2 Ouray Invasions from 1985 to 2010
ACRONYMS & ABBREVIATIONS HERE
Old 08-20-2018, 09:31 AM
Neither configuration is going to allow you run with the gate window down but I agree with Don the corner wings do work better than the goofy single roof mount.
Wind Deflector on GW cwtdaly General FSJ Tech 13 07-14-2017 10:33 PM
Fog lamps & Air Deflector mounting + more questions KiwiWagoneer General FSJ Tech 6 10-20-2016 07:22 PM
Aftermarket Front Air Deflector? scatlin General FSJ Tech 3 04-10-2012 05:29 PM
Rear wind deflector, how to install? Mark G General FSJ Tech 9 05-23-2010 01:33 PM
