Hi, could anyone tell me what the stock measurement is from the front axle to the fender on a J20? This would tell me lift height correct? It has 35s on it and they do not rub. No cutting has been done. Also the rear has a spring over axle set up not sure if thats stock. The rear springs are like flat but they have a good 6in spacer between the axle and the spring. I assume they are stock springs just spaced. Any thoughts?
Thanks
Thanks
