01-20-2022, 01:20 PM
Front differential vent
Hey guys,
Just checked the differential fluid levels in my 74' Cherokee and when I removed the front plug vanilla milk shake poured out. I noticed the vent tube was missing and obviously got a lot of water in there.
It's a Dana 44 and the hole is in the top driver side of the diff housing and I am trying to figure out if it is a press in or a threaded hole. I raked a pick inside the hole and couldn't feel any threads so I think maybe a pressed in fitting??
If anyone knows what I need I would appreciate any advice.
Gotta get a new gasket, lube and whatever I need to install the vent line...
Gonna be fun to clean it out....or not.
01-21-2022, 10:33 AM
Originally Posted by mwood65
Hey guys,
As I recall, it's a pressed-in tube (and lame). They come loose easily. Anything you can figure out has to be better than the orginal.
01-21-2022, 11:59 AM
Any I have seen are just pressed in tube.
easiest solution is tap the hole and screw in a barbed fitting.
01-21-2022, 01:38 PM
Yeah, That's what I figured doing, Looks like about a 3/8" hole...
Thanks for the input!
01-21-2022, 01:40 PM
Careful what ya say there fella! I can "figure out" some crazy stuff.
Just gonna tap the hole and use a screw in barbed fitting (with lock tight) and then run the vent hose up to the inner fender somewhere...
01-21-2022, 02:20 PM
... then run the vent hose up to the inner fender somewhere...
From the factory, they run it up to a loop clamp on one of the radiator bolts. The end of the hose has a vent cap that should seal out large amounts of water. Like this, but $10 each seems outrageous.
www.summitracing.com/parts/rnb-924-284
01-21-2022, 03:12 PM
autozone $5.99
01-22-2022, 03:13 PM
Well....
The diff was cleaned out thoroughly and a Fel-Pro gasket installed, then filled with new gear oil.
No leaks so I guess it was a win!
All the gears look great inside so it should be all good now.
Trans drained and re-filled with new gear oil and the transfer case also.
Everything is good now and after I change the rear gear oil it will all be 100%.
Don't know yet if the rear diff got water in it yet but either way it needs to be changed but I need to get more gear oil, a gasket and more brake kleen. That's a job for tomorrow....
01-23-2022, 11:08 AM
When I changed the diff fluid in the front of mine, I found a foamy mess. No idea what caused it so I just cleaned it out and put some new fluid in it.
01-28-2022, 11:06 AM
When I changed the muck in the front diff in mine, it all dribbled out through the gap where the axle tube meets the pumpkin. Guess my axle is probably bent.
( Cherokee Build Thread)
00 Baby Cherokee
01-31-2022, 01:35 PM
I would look for cracks in the housing casting. You could also use an electronic level and see if the left and right tubes are out of level with each other.
02-09-2022, 05:15 PM
Find an old skool welder and have him/her weld around it. Pretty common that the press fit/seal/glue could fail on them.
BP Drivetrain...........
775-537-7918
Thread Tools |
Display Modes |
