Old 01-01-2022, 08:55 AM
Theodore Theodore is offline
Junkyard Find - nearly complete 89-90 GW w/Original Sand Seats, Leather-wrapped Steer
Junkyard Find - nearly complete 89-90 GW w/Original Sand Seats, Leather-wrapped Steering Wheel, etc. - WooHoo!
A friend of mine was cruising a local junkyard a couple of weeks ago for late 80s Ford pickup parts, when he came upon a neglected GW sitting on the ground. Walked over to it & was surprised to see a nice set of original leather seats that matched what i need. Other than missing the 2 front doors & axles - the GW appeared complete. Over the next couple days, we went over and pulled the seats, steering wheel, radio, instrument cluster bezel, clean seat belts, back arm rests, tail lights, side markers, charcoal canister, air cleaner & snorkel, and the rear air deflector. All for $225! Can't wait to get all this stuff cleaned up & installed in ours. After cleaning, we found the seats had a few scratches, and the arm rest has a tear; so, yesterday, we dropped the seats & center armrest off with Creative Color Int'l (CCI) in Hendersonville, NC- for reconditioning. If things go according to plan, we should have them back in a couple weeks. Tripped across CCI in a forum post here that pointed to: https://fourwheeltrends.com/leather-...e-front-seats/
GW as seen
Interior as found - the steering wheel appears black from mildew.
Other parts pulled - looking forward to adding the rear air deflector
Radio - apologies for being upside down
Before / After cleaning
Armrest
Cracks will need repair
Steering Wheel - almost gave up on it - took 3 sets of bolts (2 sets of grade 8's) & PB Blaster/WD-40 to pull it
Mildew's rubbing off
With cover off & cleaned
Here's what it's replacing:
Other random parts found:
Original Jeep Fog Light covers for ROL-branded lights. Was able to get one good ROL fog light; other one was broken/rusted out.
Gas cap - found next to GW on the ground; can see it if you look close in the junkyard pic.
While we wait on the seats, a snowball's started rolling; am working on getting pulled parts installed & new parts collected for a few other things:
1) Charcoal canister - Added back along with a 2-port vacuum switch, fuel tank vent lines and associated vacuum hoses. Afterwards, took GW out for a fill-up & for the first time was able to pump gas unimpeded!. I've got a post elsewhere re: issues w/pumping gas - will update /details/part#'s there.
2) Fresh Air Vents - Cleaned out the vents & found them full of leaves & compost - no rust tho!
3) Carpet - am on the hunt for carpet, and am wondering whether to go with cutpile or essex? Have cutpile samples, and am waiting on essex samples from ACC.
4) A/C - removed the underdash duct work to ease the vent cleaning, and am going to re-do the A/C. The compressor had r134a fittings on it, so had a shop pull vacuum & fill it back in the summer; but i never got air cooled below 70 degrees... Back story: the PO pulled the motor & body together from the four-winds, so even though the compressor had r134a fittings, i don't think the body had had a proper conversion done; am going to start from scratch.
5) TBI EFI wiring harness reroute - PO used a shop to mate the engine & body, which resulted in the ECM being installed in the engine bay - ugh. Have been reading/following MysticRob's post on TBI EFI installation as prep to jumping in. Looking at getting a new wiring harness from Hamilton Fuel Injection - existing one is hacked up.
Old 01-01-2022, 04:41 PM
nograin's Avatar
nograin nograin is offline
Nice find and nice haul!
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 01-02-2022, 01:25 PM
Thanks; it's still hard to believe we found this stuff all in one place.
On another front, continuing to install parts from the junkyard haul:
Next up, the radio - installed & it works! It replaced one that had a dead display.
Non-vented Gas Cap
Underhood - installed air cleaner & snorkel; adding to the charcoal canister that went in the other day. Still need to move the ECM under the dash & clean up the EFI wiring. Even so, still looking more original than ever.
Old 01-02-2022, 01:33 PM
backroadin''s Avatar
Wow - that steering wheel cleaned up nice!
Old 01-03-2022, 02:48 PM
SCORE!!!! Thanks for posting this!
Make sure you post up some pics when you get the seats back!
00 Baby Cherokee
Old 01-03-2022, 07:45 PM
letank's Avatar
letank letank is offline
Very good finds... cheers...
Yes JY parts can be really grimmy... once I pulled a steering column and while I had my nose almost against the steering wheel... with the summer heat... That leather had very strong BO...
The center console top leather seems to always be gone, while the bottom part is usually fairly new
Michel
Old 01-04-2022, 01:55 PM
bluehwy's Avatar
bluehwy bluehwy is offline
Man alive, I need that dash and windshield!!!
Previous: 1988 Grand Wagoneer (found recently behind a bar and passed on buying it back-too far into current build)
1989 Grand-sold to Montana
Current: 1979 Wagoneer
"Buy dirt ..." Then drive your Jeep in IT!
Old 01-04-2022, 02:00 PM
bluehwy's Avatar
Mainly I need that instrument cluster. Too bad my buddy was just in Lenoir on the 2nd. Could've sent him on a hunt for me.
Old 01-04-2022, 03:08 PM
I suppose this is a great discovery but I do not share in the excitement.
Between roughly 1995 and 2007 is what I call the heydays of FSJ collecting. This was a time when FSJs were old enough to be neglected and young enough to be uninteresting. It was also a time before the Cash For Clunkers debacle and the price of scrap steel went very high.
During this time I was buying about one FSJ per month. Rarely did I pay more than $200 or drive more than 50 miles for one.
Resistance is not futile yet.
Old 01-04-2022, 05:37 PM
I may be heading back over this weekend to pick up the heater box; realized my box has a chunk missing on the bottom - assuming it took a hit during the engine swap. If the cluster is still there, Ill pull it & give you a yell. If there are other things you need, let me know & ill ck.
Old 01-05-2022, 05:46 PM
bluehwy's Avatar
That would be incredible!
[url=https://flic.kr/p/2mVvmbt]
[url=https://flic.kr/p/2mVAcD7]
[url=https://flic.kr/p/2mVAcCW]
Old 01-05-2022, 05:50 PM
bluehwy's Avatar
Just let me know how involved ya want to get. Ha... Easy stuff would be the door lock pulls and interior door handles. Mine are tarnished pretty bad from smoke damage.
Old 01-05-2022, 06:27 PM
Ow - hate to see that. PM me your contact info; will send pix of what is here & we can go from there.
Old 01-05-2022, 07:04 PM
bluehwy's Avatar
Red face
Will do! And sorry for highjacking the thread! Wasn't my intent...
Old 01-08-2022, 07:42 PM
Update on the Leather Reconditioning
Just received notification that the leather reconditioning work is done; rep sent the following pix - they look great. Winter storm is headed this way, so it will be a few more days before we can head over the mountain to pick them up.
Old 01-09-2022, 12:35 AM
Sweet!
Great score, and nice job by the restorer with everything.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 01-09-2022, 07:28 AM
Originally Posted by MysticRob
Sweet!
Hey, Rob - question for you; one thing that bothers me, is the sun damage on the plastic back of the steering wheel makes it look like coral; know you worked at a resto shop - wondering what to do about it? Armor-All & leave it alone? Replacing it with a nicer example looks difficult, as the collar is staked. The existing steering wheel is worse.
Old 01-09-2022, 10:36 AM
I've honestly never tackled something like that pitted plastic, but I wonder if using a heat gun close to it to pull the oils back to the surface would help on the majority of the surface, then follow up with something like JB Weld Kwik Weld to fill in the pitted areas prior to repainting. Certainly would take a while to do, but results would likely look much better than what you started with.
--Rob--
My build thread:
Old 01-09-2022, 10:33 PM
Good lawdy!! Those look amazing!!
00 Baby Cherokee
Old 01-15-2022, 11:25 AM
Picked up our GW junkyard-find seats today from CCI, a leather reconditioning company; am very pleased - look even better in person. Will probably be Spring before they're in; have a few things ahead of them: EFI-related wiring work under the dash, fix the A/C, replace the carpet, then we'll be ready for seats.
