I know I can't be the only one with rusted out vacuum lines to the transfer case. What size and what type of lines can I replace them with?? Maybe just regular vac lines run in flex loom or something? Can't seem to find replacement metal lines
hELP FINDING RIGHT LINES
My J4000 has rubber vacuum lines from the switch to the case and I've never had a problem. Like you said, just secure them out of the way so they don't get snagged or droop onto the exhaust pipe.Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT RIP
I assume you mean a quadratrac. Mine just uses rubber lines the whole way and I've never had any trouble. If you go with all rubber, get the thick-walled lines. I think they are 1/8" lines.'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Originally posted by MadspeedI know I can't be the only one with rusted out vacuum lines to the transfer case. What size and what type of lines can I replace them with?? Maybe just regular vac lines run in flex loom or something? Can't seem to find replacement metal lines
JR[quote] "How does someone from Iran have a BJ's Offroad sticker but I can't seem to get one sent to New Jersey???!!!"
1966 mustang fastback
'07 Dodge Charger 3.5
