Old 06-16-2020, 04:24 AM
rambling_rebel rambling_rebel is offline
finally making time
I'm finally getting time to try and move forward a bit on my step side project
i'm a little bit stuck on one part of it
LOTS stuck on many items
but the current issue is its a 1982 step side
that i've converted to a 1966 front end
and after spending a few years trying to find the 3 piece bumper
i found one and have slowly been preparing it to go on
last night i went to mock it up and hit a snag
so i went and looked at my daughter "new to her 77 401 wagoneer" and see the difference
if you compare the front of the 2 frame rails
the 82 looks like they extended the frame rail for the one piece bumper
i'm thinking i'm not the first one that tried this
(I hope)
if anyone has done this, did they just "chop" the front and weld a front plate on to bolt the 3 piece to?
i can post pics if required
BTW old 82 bumper is for sale, i'll put it in for sale section
its in really good shape
thanks for any insight
i'd like to get these 2 FSJ's on the road this year
so i'm trying to work on them side by side
Old 06-16-2020, 07:32 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I don't know much
but I know you are correct on the frame mounts
in later years,...they were extended with three holes to accept one piece bumper
hopefully someone on here will chime in and have more details for you
but you are on the right track.
dave in NC
Old 06-16-2020, 03:31 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Send me a pic of the front bumper. I'm always looking for a nice one. I can look at my '67 and compare it to the '86 and see if I can tell the difference between the two.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 06-16-2020, 06:31 PM
Hi all, i had my "welding buddy" here giving me a sober second thought
it does look like we need to chops off the front of the frame rail
and i guess drill a hole in the crossmember to bolt to
i could MacGiver it, but it won't be pretty
so he's going to step in and do it
and hopefully not wreck my fresh paint job
sigh.....
i'll post a picture of the bumper
thanks for ringing in
rr
Old 06-16-2020, 08:20 PM
Full Size Jeeper's Avatar
BJ'S OFF-ROAD has something that might work.
Bumper Extension Brackets / Frame Horns
review0 Review(s) | Questions about this item? Be the first to ask here.
Your Price: $80.00
Free Shipping.
Part Number:05-2644
Quantity
1
ADD TO CART
REVIEW THIS ITEM
ADD TO WISH LIST
Description
1978 Wagoneer
Mods:
Old 06-16-2020, 08:22 PM
Description
Bumper Extension Brackets / Frame Horns! These brackets are a weld-on style and allows you to convert early model frame to have the same brackets as the 1979-later models. This allows you to install our later model bumpers on an earlier model rig! 1/4" thick steel plate and steel gussets, and even includes instructions!
Will not fit Ross Bell Crank Steering Equipped FSJ's (1963-1964, approximately). See Ross Bell Crank Steering style crossmember / frame picture above which shows the style this kit will NOT fit.
1978 Wagoneer
Mods:
Old 06-18-2020, 03:28 PM
The chassis changed in 78. When I swapped chassis's under mine (from a 79 Chassis to a 78 Chassis), I cut those frame horns off, the C-channel looking bumper mounts, and welded them to the 78 chassis. The 79 Chassis still had all the same mounting points and threaded holes as the 78 chassis.
I'm really interested in the bumper too!!! You willing to ship? PM me!!!
Old 06-28-2020, 02:15 PM
I have done exactly this on my old '79 Wagoneer. Just need to chop the frame extensions off and drill a couple holes in the cross member to fit the three piece bumper.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Finally running! immadrpepper General FSJ Discussion 7 11-29-2018 11:45 AM
Finally running! immadrpepper General FSJ Discussion 0 09-30-2017 02:29 PM
Finally making progress on my J10 Honcho Jeff in north Texas General FSJ Discussion 21 07-07-2015 06:17 PM
New Engine Sitting for Long Periods of Time The PIG Smith General FSJ Tech 2 01-30-2005 02:30 PM
QuadraTrac - Full Time or Part Time uglyjeepling General FSJ Tech 11 08-09-2004 04:22 PM
