Old 01-25-2016, 09:50 AM
HAARubicon HAARubicon is offline
Dash Pad repair
Well I guess since this falls under the restoration category, this is where I need to post this.
I am getting ready to tidy up the 89 grand wag, (my winter/spring 2016 project), and I need some help with this troublesome dash pad.
The passenger side where it turns down and the outside edge is delaminated from its metal support and attachment hardware. Is there a known good fix for this (I have seen others with the exact same issue) or am I just stuck with it. The pad is in great shape other than this one area.
If it can be fixed, but I have to remove the dash pad, I will need a good explanation of removing the dash pad, my research is mostly for older models and they are not trying to save it, just remove it.
Old 01-26-2016, 08:24 AM
twmattox twmattox is offline
There are a handful of nuts on the underside that are hard to reach. You will have to remove you radio / HVAC control to reach the ones on the passenger side. You have to remove the speedo cluster to reach the ones on the driver side.
And, there are 3 larger bolts up by the windshield. Generally hidden under the rubber gasket.
Old 02-25-2016, 12:08 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
dash pad
Is this about the same for an 83 Jtruck..?
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 02-26-2016, 08:59 AM
SJTD SJTD is offline
The '84 has six bolts under the windshield gasket that go through the vinyl. I doubt the later ones are different.
Hard to get to with the windshield in place to remove. They would be VERY difficult to reinstall.
Sic friatur crustulum
Old 02-26-2016, 09:31 AM
Thanks for the feedback. This particular GW is in fairly nice shape and is currently not a candidate for a full restoration, so I was hoping there was a fix without having to disassemble the dash or remove glass.
Old 04-10-2016, 08:16 PM
Pavementsux91XJ Pavementsux91XJ is offline
I don't know any quick fixes. I just took mine to just dashes in southern California. Really nice guys but they are expensive ($850 for black $950 for color match) and they have a really long lead time. I dropped mine off April 1st and expected delivery is the first week of June. I'm planning on posting up with a workmanship review in the pris section when I get it back.
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 08-05-2016, 04:27 PM
408wij 408wij is offline
Noob!
I'm in the same boat with my new GW. I also have tears on the top of the dash pad. What I'm thinking of doing is brute-forcing with screws and glue the loose corner, then recovering the mat to cover the tears and brute-force fix.
what dash fubar General FSJ Discussion 7 02-26-2016 01:39 PM
Jog my memory on our dash assemblies BamaDrew General FSJ Discussion 2 03-03-2011 06:34 PM
Trying to remove Grand Wag dash Tigger4X General FSJ Tech 6 02-03-2011 11:08 PM
FIX THAT BUSTED DASH WITH A NEW OVERLAY!! Chrome General FSJ Discussion 17 12-20-2007 05:37 PM
no dash lights WE B GPN General FSJ Tech 3 11-01-2006 09:26 PM
