Old 06-21-2014, 03:58 PM
Pavementsux91XJ Pavementsux91XJ is offline
Need help - Brake line routing J10
Soooo I took my 76 j truck apart a long time ago, now I'm trying to install a new brake hard line kit and I can't remember the routing on the rear hard line that goes between the prop valve and the rear soft line. Can somebody take a couple pics for me?
Thanks in advance!
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 06-22-2014, 02:40 PM
J10blues's Avatar
J10blues J10blues is offline
Thanks in advance!
These are from my 77 J10, it shows the lines from the prop valve running all the way back to the fitting that goes on the frame cross member where it splits from hard line to soft and then down to the splitter on the axle, hope this helps.
http://s30.photobucket.com/user/been...?sort=3&page=1
Ben
77 J10
360 complete rebuild
TH400
Eddy Performer intake/Non EGR/CompCams 268 H
Eddy 1406
MSD 4AL/MSD 8519Dist/TFI coil
Holley fuel pump
MagnaFlow exhaust
02 Jeep Wrangler TJ
_________________________________________
"Fast is Fine, Accuracy is Final, You Need To Be Slow..In a Hurry!" Wyatt Earp.
Old 06-23-2014, 09:11 PM
Helps a lot. Thanks for your time. What about the cross member right behind the cab? over, it or through one of the holes?
Old 06-24-2014, 12:19 AM
J10blues's Avatar
Brake line routing
Over the crossmember, the hard lines are bent to form over it. There are two holes on the crossmember on the driver's side, one large one and a smaller one under, only the electrical lines go through the big hole and the EBrake cable goes through the smaller hole below.
Ben
77 J10
TH400
Eddy 1406
Holley fuel pump
MagnaFlow exhaust
02 Jeep Wrangler TJ
Old 06-28-2014, 03:19 PM
THANK YOU!!!!!!
Brake Line Length Thomas792 General FSJ Discussion 2 10-05-2012 08:10 AM
SS Brake Line Installation ? barlowchiro General FSJ Tech 6 06-07-2012 05:19 PM
Brake metal flex line. GWDriver General FSJ Tech 4 10-16-2009 12:29 PM
brake line shackwrrr General FSJ Tech 2 06-16-2006 08:30 PM
fuel line routing robsgp General FSJ Tech 5 12-05-2005 05:51 AM
