06-19-2014, 05:57 PM
Always Broke
Rear disc brake conversion - what about proportioning valve?
So I am getting rear disc brakes with my upgraded axles. Who's swapped to rear brakes and did you have to do anything with the proportioning valve?
06-19-2014, 06:45 PM
I installed rear discs years ago never touched valve.
Also added HB years afterwards again never touched valve.
Others have added rear discs and been fine.
My .02 your mileage may vary.
06-19-2014, 09:05 PM
What he said,,,exept didn't do HB.
Stops,,,NOW...not sliding tires too.
No valve change.
J20
BP Drivetrain...........
775-537-7918
06-19-2014, 09:59 PM
Always Broke
ok cool. I am going to run it at Ouray without changing anything.
Dual diaphragm upgrade when I get back and if I don't like that I will do a hydro boost.
In Ouray a few guys will be HB'd I will see if they will let me drive their rig a little.
06-19-2014, 10:17 PM
I have both rear disc and HB on mine. I did not touch the prop valve either.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains ( Project Link)
06-20-2014, 06:52 AM
Always Broke
Scott you are making Ouray again this year right? I might ask to drive it a little bit and feel your brake setup.
06-20-2014, 08:04 AM
I will be there but in a rental jeep
Scott R.
06-20-2014, 04:33 PM
Always Broke
Well who's going to strap Jeeps down Engineer then?
06-20-2014, 05:20 PM
Art
ASE Master Collision Tech
06-22-2014, 08:32 AM
I changed the prop valve to a disc /disc version when I put my d60 axle in , they are available from summit , if your rig had disc in front stock it has a disc /drum valve , this holds more pressure in the rear lines to keep the drum springs from pushing back oil & causing more pedal travel , my thought was not to let the rear brakes be kept that tight , so pads are not worn out as fast & free rolling is achieved (mpg) , I haul heavy squat loads of firewood & a trailer this set stops very nice .they also sell a adjustable version
burt
06-22-2014, 02:40 PM
I put rear discs on one of my Jeeps.
I only added SS braided lines, disks, and calipers.
Everything else is stock and so far it's been good.
76 Cherokee Camo(Parts)
76 Cherokee Camo 401/TH400/Dana300/HD44/14bolt/36s
77 Cherokee blue 360/T18/D20/33s
1969 AMC Javelin SST 390
1968 AMC Javelin SST 290 (Parts)
06-22-2014, 05:12 PM
I installed the kit offered by BJ's Offroad. I prefer to not piecemeal and stitch things together. Although, I'm sure many projects are successful using such a strategy. I prefer to to upgrade the whole enchilada at once, if possible. That being said, I went with a new disc/disc master cylinder, a new hydro boost, and the new fixed proportional valve supplied in the kit, by BJ's. So far, the results have been trouble free, excellent braking for the FrankenWagon. In my opinion, the braking experience could only be made any better with the addition of ABS or super high quality calipers, rotors, and pads. (Read super custom here)
PS. Although Wilwood does offer a nice two piston caliper for use the Wagonner. I expect to be upgrading to those calipers in the future. Just not now.
~Jim Sherlock~
06-23-2014, 09:22 PM
Burts right. Most factory disc/drum prop valves have a 3-10psi residual pressure valve in them to keep some pressure on the wheel cylinders (supposedly keeps the seals pushed out so they don't leak, keeps the shoes from coming too far back etc etc etc) If it still works it needs to be taken out
as it can cause the rear calipers to drag. best advice is to take it on a good test drive after your done and really pay attention for any dragging noises or feeling from the rear end. after all, the seal in the valve is probably shot by now anyway and it doesn't take much to bleed off 10 psi from a hydraulic system.
Learned this the hard way with the swap on my XJ. I thought it was chatter from my fresh rearend at first, nope just brakes grabbing all funky.
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
06-23-2014, 10:03 PM
Always Broke
That's interesting. I didn't know that. One thing I will do is drive it a bit and then compare front/rear rotor temps. If the rear is hotter they might be rubbing during 'normal' driving.
06-24-2014, 09:01 AM
Banned
Your fronts do most of the braking so they should be hotter anyway.
But then, they are dual vented disks so they shoud cool. Most rear disks I've seen are single. Will they cool better?
And after 1982 I think all front FSJ disk brakes became free-floating to remove drag issues so mileage would improve.
So...with all that in mind...what do you really think higher temps will indicate?
06-24-2014, 09:25 PM
Always Broke
If I drive it and the temps are a lot higher than the front it will indicate possible dragging. If they are not much hotter than, say, the axle it might indicate not dragging. Mostly just using it as a reference point. Do you have another idea?
06-26-2014, 11:14 AM
Banned
Nope. No experience with aftermarket brake mods.
But without a baseline, you are really applying test results to an assumed theory...not really worth much unless you see a massive difference between the front and rear rotors, but then what do you attribute it to? smaller rear rotors, more drag, or mis-adjusted prop valve pushing more fluid to the rear?
I'd drive it, if you toast axle seals or bearings or you smell hot brake pads, something is wrong.
07-06-2014, 11:02 PM
I made no changes to Prop valve with my conversion..No problems so far.
78' J-9, 96' XJ
07-06-2014, 11:27 PM
what do you guys with rear discs do for E brake?
Ken's:
1966 Super Wagoneer
5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
07-07-2014, 07:51 AM
Line locks, they plumb into the brake lines...
When I was chasing this down a few years ago, I remember reading about pulling the residual valve out of the rear port on the master cylinder. The article I read (cant find it, think its gone) talked about using a second used master for the front valve into the rear port. Here is a thread discussing it on the binder planet, with an article about it...
http://www.binderplanet.com/forums/s...d.php?t=110583
Thread Tools |
Display Modes |
