03-06-2014, 05:10 PM
threaded rod for water pump/timing cover bolt
Can I use threaded rod to replace the long bolt in the water pump that holds the power steering/air pump? Upon removal I twisted the bolt and is somewhat deformed.
1991 GW TFI GM-icm 360 727 np229
03-06-2014, 05:17 PM
sure. get grade 5 or 8.
03-06-2014, 05:35 PM
Any idea where I can get it? all I found was zinc coated it says swl 1700 lb
03-06-2014, 05:37 PM
my hardware store has it. auto parts store should too. try a home depot.
03-06-2014, 05:43 PM
ok thanks
03-08-2014, 09:22 PM
Fastenal has it. Grade "b7" is similar to grade 8.
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
03-09-2014, 11:18 AM
Where I am at certain Ace Hardware stores have the best selection of bolts and nuts. That is where I have been going for all my needs. I just replaced the water pump and thermostate housing and changed all the bolts.
03-10-2014, 10:15 AM
As a last resort - McMaster-Carr
http://www.mcmaster.com/#standard-threaded-rods/=r18v74
When I order from them on Sunday, it arrives on Monday, sometimes Tuesday. Shipping is reasonable too.
We use them a lot here at the lab, when we need hardware and such stuff.
Thread Tools |
Display Modes |
