Old 02-02-2014, 10:47 AM
miltos68's Avatar
miltos68 miltos68 is offline
4.8L in a 68
Is this enough for a 4k gvw? I know there is no replacement for displacement. This vehicle will tow small trailer and family once a year playing Griswald cross country. The rest of the year it is commute. What do you think is the 4.8 capable? I mean I wont be pulling a 26ft mega trailer just a 16ft shasta or similar.
Old 02-02-2014, 12:04 PM
Mike D's Avatar
Mike D Mike D is offline
Or a 41' Vagabond (ps it's 3K-lbs) ...
lol -- get this, it was manufactured in 1950 ... and was pulled by many Wagoneer/ford/Studebaker etc .... -- harry right??
64 Wagoneer 283 SBC
50 truck
63 J-200 Truck -- free
Addendum:
Old 02-02-2014, 12:32 PM
The 4.8 will pull plenty...what I would be more worried about is upgrading your brakes and suspension.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 02-02-2014, 01:42 PM
miltos68's Avatar
thanks I take it 4l60e will give me better mpg than the th400 and should be better all around?
Old 02-02-2014, 02:06 PM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
I know I'm gonna get slammed by some, but......
Looking at the torque and horsepower numbers the 4.8 looks better than any of the stock jeep drivetrains. Add a significant mileage increase from the overdrive, and the improved reliability and drivability of the GM LS series engines, not to mention parts availability, there is no downside to the swap. Except for blood sweat tears and money.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 02-02-2014, 02:38 PM
miltos68's Avatar
I have no shortage of any of those variables save money. I have ordered the engine from BD turn key. Hope I can find a transmission w/in my budget. I'll buy the adapter when I can save enough. Wish I could use the stock adapter for a 4l60e. Now I just need the motor Gods to keep this 50 psi compression motor putting and gross polluting for 5 more months.
Old 02-02-2014, 10:07 PM
miltos68's Avatar
Vagabond awesome. I would not do anything but park that. I could use a littleore input on this subject because the owner st bd turnkey is telling I will be highly disdapointed with the 4.8 but I have posdative input here. I cannot afford to buy amd find out for myself I could use some help from som wogoneer owners please. Thanks a bunch
Old 02-02-2014, 11:59 PM
And the ability to do the wiring!
Old 02-03-2014, 04:55 AM
mdcptman's Avatar
Jeep Therapist
Ok...juat to clarify, I think the 4.8 woild be a good motor to swap in. If you can get a significantly better deal on one, then its worth it. But given a choice, I'd rather the 5.3. I have one in my tahoe, and it can pull anything, at 80, and still get 18 mpg. At 185000 miles.
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 02-03-2014, 12:57 PM
jdaniel83's Avatar
jdaniel83 jdaniel83 is offline
I think the 4.8 would be fine. Depending on what configuration the motor is you're looking at around 270-295 HP and 285-300 FT/LBS of torque which is more than adaquate to move around an FSJ. Yes the 5.3 is more powerful but like mdcptman said if you can get a good deal on a 4.8 I would go that route. Biggest difference you would notice between the 4.8 and 5.3 is when you would be towing because of the torque difference.
'89 GW; 4" Susp Lift on 32" Wild Country MTX; 360, HEI, Edelbrock Intake, Melling MTA-1 Cam, Summit 600 carb, 3.73 Gears
'70 Wagoneer; stock Buick Dauntless 350, TH400; 3.73 stock gears
'83 Wagoneer Limited; stock 360, 727, 3.31 gears.
Old 02-10-2014, 12:32 PM
miltos68's Avatar
well a fool and his money as they say. I bought what I was told was a 5.3 and it turns out to be a 4.8. I wonder what other truths may have been stretched.I doubt the calls will be returned. should have gone bdturnkey.
Old 02-10-2014, 01:24 PM
It's really hard to tell the difference w/o looking @ a piston.
Not making excuses for the seller, but they might have thought it was a 5.3
I bought a 5.3 a while ago, and the seller neglected to mention a few things.
Like the fact that he never changed his oil?? Lotsa sludge inside.
And the broken water pump bolts snapped off in the block.
Still got a good deal IMHO, provided it runs?
Old 02-10-2014, 03:09 PM
miltos68's Avatar
I am going to run it anyway since I ended up with it. I did not realize the the mark is on the head gasket tab pass side (4.8 or 5.3) . I just worry about torque. the 350 dauntless had higher torque rating than this small block. I do not want it to be disappointing come tow time. Just don't know?!
Old 02-10-2014, 11:44 PM
mdcptman's Avatar
Jeep Therapist
I think you will be pleasantly suprised. Its a good motor, and there are loads of aftermarket stuff available to help u get more power if needed.
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 02-11-2014, 12:21 AM
miltos68's Avatar
i have a 68 and do not require smog checks. I do not have cats for this motor and wonder if it would be ok to run without them. Too little back pressure? Beneficial? dont know cant find too much info on this aspect of these motors.anyone have anymore knowledge on this.by the way thanks for the praise on this motor I fear I might be struggling to tow.Granted it will not be more than a 4k lb travel trailer but feel that the GVW is 2k lbs less than the vehicles tey come in now it might work out ok. I don't want to be struggling up over the rockies with the family at 4500rpm at 45mph.
Old 02-11-2014, 06:42 PM
As long as you have mufflers it will be fine.
Old 02-11-2014, 09:01 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
There is no such thing as too little back pressure.
Old 02-12-2014, 01:33 AM
miltos68's Avatar
turns out as well as not being a 5.3 it is a 1999 and not a 2006. man I am a sucker!Boy I used to pride myself on character judgment. I must re-think my attributes. the 1999 4.8 is 35 hp lower than the 2006. I do not know how to tell the wife I wasted our savings on something that just wont work for what we need!!! 255hp and asthmatic torque numbers will not do. man I am lost on hoe to make this wrong a right. to hell with people trying to get over on other folks.
Old 02-12-2014, 05:50 AM
mdcptman's Avatar
Jeep Therapist
Awe man! I hate that! I dont know how some people sleep at night!. There are lots of aftermarket parts to boost hp. But maybe u should sell it, recoup some of your money, and look for what u want. Is there no way to go back the seller? Hes not returning calls?
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 02-12-2014, 09:47 AM
miltos68's Avatar
He returned my call and apologized said he did not know.Refund was out of the question though stating that it was my responsibility to know what I was buying.There is some truth to that but false advertisement is just that.
GM 4.8L Vortec into Jeep CJ10 (GW frame) DrJekl General FSJ Tech 12 07-31-2009 04:03 PM
