Old 03-31-2020, 11:29 AM
Beach_Dude's Avatar
Beach_Dude Beach_Dude is offline
Air noise
I've tried to figure where this air noise is coming from. I just finished the rebuild of the driver's side door, in hopes that it was from that. But, no success.
Is anyone familiar with air noise from the lower driver's side of windshield?
Could be from behind the instrument cluster, but it's literally right at the edge of the dash (while moving hand around I can hear location.
Here's a video: https://youtu.be/IPhUwCdEa1Q
1977 Jeep Cherokee Chief
360 w/ MC 4350
All stock but ignition and slightly modified suspection
Original paint, garaged/non-op for over 15 years
Old 03-31-2020, 11:46 AM
For tough to find ones we used to cover suspect outer areas with tape.
When the noise goes away...
Areas to look are fresh air vent(s) or cowl seams leaks for what you describe.
Mirrors, panel gaps, trim sticking out, weatherstripping, all of them can cause noises too.
Due to the box on wheels and lack of aerodynamics, these things tend to make a lot of noise.
Old 03-31-2020, 09:15 PM
Beach_Dude's Avatar
None of the gaps made any difference.
I'm going to try pulling the windshield and resealing.
360 w/ MC 4350
Old 03-31-2020, 09:21 PM
Check where cowl meets body way up under dash?
1/4" gap there from factory where seam sealer dude missed the joint on one I had.
Old 03-31-2020, 11:07 PM
I was going to suggest that. If I remember correctly it was a big blob of bondo like stuff that maybe fell out.
I made some plugs out of 1/8" ABS and glued them in with urethane seam sealer.
Old 04-01-2020, 09:11 AM
Beach_Dude's Avatar
For this location, what's the easiest way to access it?
360 w/ MC 4350
Old 04-01-2020, 10:57 PM
Through the heater intake hole on the passenger side. I cut a matching hole on the driver side. I don't think you can get up in there otherwise.
Old 04-02-2020, 12:54 AM
What about the missing antenna hole?
Old 04-02-2020, 12:44 PM
Beach_Dude's Avatar
Antenna plug is in, and WTF?!? How the ***K and I supposed to get up there. Certainly not cutting a hole in the firewall.
Maybe pull the cowling off and access from there?
360 w/ MC 4350
Old 04-02-2020, 01:18 PM
If on driver side gotta lay on your back with head stuffed as far against firewall possible.
Shine a good light up there and you will see the body seams/sealer they used. a gap will be obvious.
Alternatively remove cluster and check things out.
passenger side AC unit has to be dropped.
you can buy cheap usb lighted camera too and use one of those.
Old 04-02-2020, 03:40 PM
levelhead's Avatar
levelhead levelhead is offline
The look on your face in the pic:confused......I know that look
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
1969 J3000 (2)
Old 04-03-2020, 10:35 AM
I bought one of those $20 flexy cameras on a “snake” from Walmart. Came in handy searching for where stuff was under the counter.
Old 04-11-2020, 08:54 PM
BBWWAHAHAHAHAHAHAHAAH!!!! I thought the EXACT SAME THING!!!! like EXACTLY word for word! HAHAHAHAHAAHHA!!!!
Old 04-12-2020, 06:21 PM
Hahahaha! I know that Jeep "bone".
Definitely a source for cabin leaks.
Old 04-12-2020, 07:07 PM
Wait... your antenna hole is on the driver side? Is that factory? I thought they were always on the passenger side...
My goodness that red looks fantastic...
Old 06-10-2020, 04:00 PM
Beach_Dude's Avatar
There is a hole on both sides of the car that fit for antenna, but I don't know why. There was a factory rubber plug, which I recently redid since it was getting brittle.
360 w/ MC 4350
Old 06-11-2020, 08:58 AM
Do not assume that Jeep sealed all the panels. This is from my J20, looking up above the AC unit at the area above the passenger floor vent:
Old 06-12-2020, 08:15 AM
Jeep may not have done a good job sealing that gap but at least the antenna wire grommet isn't doing anything either!
Air Pump affect MPGs? Cory General FSJ Tech 16 12-26-2012 07:08 PM
Air Pump affect MPGs? Cory General FSJ Tech 1 12-22-2012 02:26 PM
Is this my problem ? (Fuel Filter position) drcom General FSJ Tech 45 10-02-2012 09:00 PM
Cold air intake ld8 General FSJ Tech 24 06-26-2012 04:24 AM
Q-Jet rebuild, How hard? porkchop General FSJ Tech 6 04-17-2002 03:01 PM
