Old 03-05-2014, 02:10 PM
Rock Creek Rock Creek is offline
Yellow switch on dash?
Hey everyone, so I've been working on getting a '79 J20 shipshape, and the wiring has been giving me all sorts of trouble. There is a yellow pull switch located on the lower left of the steering wheel (next to the horn and driver side foot vent) which seems like it might not be stock. It has had no apparent purpose until I pulled it yesterday, which caused it to turn on the drivers side footwell/courtesy light. The problem is that now that light doesn't come on with the other interior lights. The yellow switch will turn it on, and the AC fan dial turns it on instead of the fan. Also the radio no longer saves presets when the ignition is turned off. I think this is probably the result of some shoddy wiring on the part of the PO, so if someone could let me know if that yellow switch is supposed to be there or not and what it might do that would be phenomenal.
Old 03-05-2014, 02:15 PM
well,your horn is not on the wheel either so you have creative wiring going on.
Old 03-05-2014, 02:38 PM
x2
Don'tcha just love PO's and their "improvements?
Old 03-05-2014, 02:45 PM
vacaisle's Avatar
vacaisle vacaisle is offline
snide. snarky. grease covered.
Originally Posted by joe
x2
I put my horn button on the outside of the truck so if I hit somebody it goes off automatically.
89 Grand Wagoneer
145,000 miles, TFI, MSD 6a
Old 03-05-2014, 03:42 PM
jamesdart's Avatar
jamesdart jamesdart is offline
This reminds me of an f150 I had. The horn button fell off so I tek screwed a push button from the auto parts store right to the steering wheel where the factory button fell off.
1978 wagoneer, jasper 360 performer intake holley 600,700r4, twinstick dana 300, dana 44s with 4.10s and Yukon zip locker, York oba, 4" rusty's spring lift, 33x10.50 km2, ramsey ford front bumper with worm drive ramsey winch, 4" pipe air tank rear bumper with spare tire swing out.
Old 03-05-2014, 07:23 PM
serehill serehill is offline
Gone,Never Forgotten.
yeah
You can only dig into it. There's several things at issue no doubt maybe a blown fuse. There are 2 + wires that go to the radio one is a hot all the time for memory & the other is from the ignition to turn it on & off. It's a matter of tracing it all out. We could all guess until next year.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-08-2014, 09:20 PM
Pavementsux91XJ Pavementsux91XJ is offline
Wow, Please don't take this the wrong way but I do not envy you. My painless wiring harness that I have to get to work with the Howell EFI harness now doesn't seem so bad.
GOOD LUCK! I'd buy you a beer for your misery if you were closer
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 03-14-2014, 02:28 PM
Thumbs up Solved!
Thanks for all the advice! After realizing that the bumper mounted lights were not stock (they looked perfectly in character) I was able to trace the wires to the problem source under the dash. I won't describe the unsafe and horrific nonsense I discovered there, but after much rewiring I was able to disconnect the switch and hook the ac back up to its place in the fuse box. It is now working great and I no longer have a lurking fear of an electrical fire. Thanks again!
Old 03-14-2014, 03:26 PM
vacaisle's Avatar
Glad you got it.
89 Grand Wagoneer
Electric Tailgate Window Troubleshooting jbentley General FSJ Tech 56 08-18-2020 12:52 PM
4WD dash vac switch Allynr General FSJ Discussion 13 04-26-2011 10:49 AM
Press my heater fan switch and dash light go off 1jeep4me General FSJ Tech 2 08-21-2010 10:57 PM
access to rear window switch without removing dash? WWI Flying Ace General FSJ Tech 2 03-29-2010 08:42 AM
