Old 03-04-2014, 09:11 AM
earlb74's Avatar
earlb74 earlb74 is offline
Lift / Steering
Hi, just recently I installed a Rusty's 4" lift with Goodyear 31x10.50x15 tires and so far I am very please with the look and the ride. My question is what can I do to tighten up the little bit of play in my steering. For example... If I hit a bump the steering seems to sway from one side to the other. Its not bad but I would like to fix it if possible.
Old 03-04-2014, 09:53 AM
RED88's Avatar
RED88 RED88 is offline
Exclamation
check your tie rods and replace, check steering stabilizer replace, on mine I also bought a drop pitman arm from BJ's to keep things level as they should be.
I would also re torque all bolts and have a well known shop align it. have you also checked your shocks?.
All add up to a loosey loosey feeling.
Old 03-04-2014, 10:05 AM
earlb74's Avatar
Thanks, the kit came with new shocks but I was told I didn't need a drop pitman arm. I will check everything else you noted, thanks for the reply.
Old 03-04-2014, 11:05 AM
serehill serehill is offline
Gone,Never Forgotten.
If you didn't have it before you did the lift.
Then the springs may not be tight enough. Or you do need a pitman. I put pitmans on both of mine & did see a difference in what is called bumpsteer. this is where the steering seems to turn some when it hits a bumps. But if it is everyday slack make sure you snugged up the springs to specifications when you installed them. If the shackles are loose it will case slack.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-04-2014, 11:28 AM
Coondawg Coondawg is offline
You have changed the steering geometry by modifying the suspension. Alignment is necessary. Yes, you probably have aged steering joints, but definately have an alignment done.
Old 03-04-2014, 11:44 AM
vacaisle's Avatar
vacaisle vacaisle is offline
snide. snarky. grease covered.
I had that same problem, though I don't have a lift, and I replace the steering stabilizer and it was much better.
89 Grand Wagoneer
145,000 miles, TFI, MSD 6a
Old 03-04-2014, 06:06 PM
DanHS's Avatar
DanHS DanHS is offline
New tie rod ends, dropped pitman arm, and an alignment. You've changed the suspension and steering system geometry, now the drag link is at an angle because the tie rod is about 4 inches lower than it should be. Each time the suspension flexes the drag link is now getting pushed or pulled because it's not level.
'84 Grand Wagoneer 360/727/229, 32" General ST's and 36" Swampers, 3" lift, TFI/Mallory 6AL, CS 144, Taurus fan, custom bumper, and custom 'bodywork'. Soon to have 6" lift
'79 Cherokee S 360/T15/D20, rusting away while I figure out what to do with it
'91 Final Edition GW in Spinnaker Blue!
My FSJ pics
FSJ Grille Identification
Old 03-05-2014, 12:27 AM
ThaCrabapple's Avatar
ThaCrabapple ThaCrabapple is offline
DPA will almost fix your geometry. Should help mitigate bump steer
1979 Jeep Cherokee
AMC 360(Edelbrock everything...)
TH400 Hurst Shifter
6" Lift
35s
Beauty.
Old 03-05-2014, 06:48 AM
earlb74's Avatar
Thanks for all the suggestions, I am ordering parts today!
Old 03-08-2014, 09:15 PM
Pavementsux91XJ Pavementsux91XJ is offline
DanHS is right. What year are you working on? The term is "Bump Steer" Is it a newer model with a track bar or no? Did you remove it?
Theory...if you care: Imagine a 30,60,90 (isosolese?) triangle. The bottom side would be your axle, the long side is your drag link, and the upright side is the distance between the axle and your frame. As your suspension cycles, the length of the upright side changes, and since the axle can't get wider or narrower, and the drag link, obviously, can't change lengths, the only way for any movement to happen is for the drag link to push or pull the steering, when this happens, the steering wheel will rotate. If you have a track bar (forgot when they started using them), the track bar will push or pull the axle off to one side and thus eliminate the bump steer.
Ideally you would want to have a track bar the same length, and at the same angle as your drag link.
A drop pitman arm can "fix" the problem by moving your drag link closer to parallel to the axle so the change in the length of the "hypotenuse" isn't as great. And therefore, the minimal bump steer is not noticeable.
Hope this all makes sense.
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 03-12-2014, 06:03 AM
billyj7175's Avatar
billyj7175 billyj7175 is offline
I ran a 4" Rusty's lift on my J10 for many years before installing a DPA...wish I had done it sooner.
83 J-10 Jeep "Oscar"
360/727/229
4" Rusty's w/33X12.50 BFG AT's
I'll apologize ahead of time...my inner voice has Tourette's...
Old 03-12-2014, 07:23 AM
jamesdart's Avatar
jamesdart jamesdart is offline
Yeah I ran mine for a year before I did the dpa. Drives much nicer on the highway. I the did the j20 box which was also a nice upgrade.
1978 wagoneer, jasper 360 performer intake holley 600,700r4, twinstick dana 300, dana 44s with 4.10s and Yukon zip locker, York oba, 4" rusty's spring lift, 33x10.50 km2, ramsey ford front bumper with worm drive ramsey winch, 4" pipe air tank rear bumper with spare tire swing out.
Old 03-12-2014, 01:51 PM
JDD JDD is offline
Post some pics!
Old 03-12-2014, 07:16 PM
CutterN55's Avatar
CutterN55 CutterN55 is offline
Fist sentence yes, second...NOPE alignment is not necessary.... At least not in most situations. If the caster and camber didn't change or the the steering linkage, tow, and rod ends haven't been messed with (with exception of the drag link) and the truck was aligned prior to lifting, alignment would be a waste of time and money for a solid axle, leaf sprung truck.
Get the drag link angle down with a DPA first. That will likely solve your issues. Then address your bushings and look for worn rod ends. Caster can effect bump steer if it's real negative, but a 4" kit with proper pinion angle is not going to put your caster so far off that it becomes a problem.
A 4" lift on an FSJ hardly requires diddly squat other than longer brake lines, shocks, and a DPA which some folks don't always feel they need. If the lift kit didn't come with pinion angle shims, seperately or built into the spring, you might want to throw some in there.
ROMANS 12:1-2
Military guys- Check out www.MilitaryJeepers.com
'89 GW deceased
Ford 4spd swap Np435/205
Lifted/stretched on 36's/4.10 thick gears/spooled rear
'86 CJ-7 Renegade, Restored, original steel.
new Built TBI 258/Np435/D300 twin-sticks/Waggy D44's
37" Super Swampers and lots of goodies!
Old 03-25-2014, 01:09 PM
earlb74's Avatar
Originally Posted by JDD
Post some pics!
Old 03-25-2014, 01:10 PM
earlb74's Avatar
Thanks CutterN55.. Where do I buy pinion angle shims?
Old 03-25-2014, 08:00 PM
will e's Avatar
will e will e is offline
Always Broke
Well if it drives funny it sure looks good doing it!
I did the DPA on my lift after the fact and found it to be helpful.
I also replaced the rag joint steering with u-joints. You can buy the shaft from BJ's (expensive) or do a search on using xj parts on this site.
Old 03-26-2014, 11:01 AM
earlb74's Avatar
Thanks Will E, I installed the DPA after mine as well. Looking in to the rag joint upgrade as we speak.
Old 03-26-2014, 04:43 PM
CutterN55's Avatar
Most 4x4 parts retailers sell them. I've seen them on Amazon, eBay, and several of the common retailers. Google is your friend.
ROMANS 12:1-2
'89 GW deceased
Power Steering Problems......Please Help!!!! ThickMick12 General FSJ Tech 10 08-26-2011 05:57 PM
Steering woes continue, getting annoyed... DanHS General FSJ Tech 11 06-22-2011 08:46 PM
Body Lift Steering?? xsloppyjoex Off-Road FSJ Tech 13 02-05-2011 09:15 PM
