  #281
Old 09-30-2012, 06:05 PM
jMedia's Avatar
jMedia jMedia is offline
I may be dumb and missing something but isnt it somewhat dangerous having electrical jumper connections around fuel?
Joshua
Constantly changing, never done
Old 09-30-2012, 06:49 PM
Mikel's Avatar
Mikel Mikel is offline
Diesel fuel is much less volatile than gasoline.
1969 M715 6x6
1963 J300 Swivel frame
Old 09-30-2012, 08:12 PM
tndonor tndonor is offline
The filler neck is not a part of the fuel system on my truck. I have a bed mounted auxillary tank.
1980 J10 4BTA (p pumped) NV4500, d300, np205. Dana 60s Sold and parted out
1967 M715 Cummins 6B p7100
HX35/HT3B compound turbos. NV4500. 203/205 Doubler. 14B FF 4.56 Detroit/ HP60 4.56 OX
Old 10-01-2012, 02:07 PM
jMedia's Avatar
Ahh ok. Got it and got it.
Joshua
Old 10-11-2012, 07:26 PM
Phillips889's Avatar
Phillips889 Phillips889 is offline
Whats the Plan B Switch do?
1981 j10 cummins diesel Daily driver UP AND RUNNING!
1979 J20 PARTING OUT SEE PARTS FORUM
1979 Cherokee widetrack up on blocks.
Old 10-12-2012, 04:30 AM
It fires some rocket motors to gently lift me off of an obstacle or a stuck..... I mean it arms the in cab winch controls for front a rear winch.
Old 10-12-2012, 04:34 AM
Aux 1 and aux 2 will be lights on front and rear bumpers. My sister bought my a 300 ammeter from a B17 bomber Im trying to incorporate into the alternator/welding circuit.
I need to quit adding stuff. I have a problem I think.
Old 10-12-2012, 06:39 AM
Resbum's Avatar
Resbum Resbum is offline
Very Cool!
I know how you feel. I started my build only planning to rebuild the Buick 350 that came in my truck.
Originally Posted by Resbum
"What year is my truck?... Which part?" Build thread- http://www.fsjnetwork.com/forum/view...p=18290#p18290
Old 10-12-2012, 10:27 AM
Apparently I have a disease. Timolol. Used for high blood pressure amongst other things. So my Jeep is medically necessary to keep my blood pressure in check
Old 10-14-2012, 10:47 AM
glenn715 glenn715 is offline
Noob!
I will have to show this to my wife. See honey its for my health.
Old 01-14-2013, 08:06 PM
Time for some small updates. Now that the flu season, holidays, work, and emergency home repairs have passed progress came begin on the final push. First order was to fles the suspension out and measure for driveshafts and shocks. I got to drive the truck! Granted with no brakes or engine not sure if it counts. Felt good all the same.
Old 01-14-2013, 08:08 PM
Rear driveshatf should be ready to be picked up tomorrow.
Shocks are Fox 2.0 16" remote reservoirs. Not wild about chrome but what are you going to do?
Going to wait until the driveshaft is on before bending the rear shock hoops just in case
Old 01-14-2013, 08:10 PM
scorge30's Avatar
scorge30 scorge30 is offline
Looks good keep the updates coming please.
'83 Cherokee Pioneer status: it's alive!! (with a horrid exhaust leak!)
Rebuilt AMC 360
Rebuilt TF 727 with HP parts (again)
Here is the electrical panel up on the roll bar. This has the controls for both winches, aux battery, electric fan, wipers, rock lights, front bumper light, rear aux light, air horns, air compressor.
Old 01-14-2013, 08:13 PM
I added an auxillary light inside the lid of the fuel tank/toolbox. The idea was to provide a work light if I need to work on something in the bed at night. The light is bright enough to illuminate the ground 100 feet behind the truck too. It is an eliptical pattern. Light is a Vision X Solstice IIRC
Old 01-15-2013, 06:52 AM
Resbum's Avatar
OK, I'll bite... "Plan B"?
Old 01-15-2013, 09:13 AM
FSJ Guy FSJ Guy is offline
ABORT MISSION!!!!
Ethan Brady
www.bigscaryjeep.com
Old 01-15-2013, 12:35 PM
Plan B arms the winch controls haha. I guess it should be plan E or F
Plan A- try to negotiate obstacle
Plan B- back up and try again
Plan C- 4WD
Plan D- engage reduction on doubler
Plan E- Spool large turbo and dump clutch
Plan F- winch my truck as I have broken the driveline
Old 01-23-2013, 11:47 PM
Tnfalconer's Avatar
Tnfalconer Tnfalconer is offline
I like your build, I have read it front to back. I am a 715 guy as well but never built one with a cummins in it....Yet. I have a design question about your truck. Why did you choose to shackle the front spring in the rear Vs. the front like a jeep? Is there an advantage to it? I am building a 70 gladiator and rebuilding my suspension under the frame rails as you have done with some differences. I have not started, but I planned to shackle in the front on the front axle to allow the axle to move forward under articulation. My truck has the fender flares removed and will be getting fabricated flat fenders so I have the room.
Old 03-02-2013, 06:00 PM
She lives
A cruel teaser
