Old 10-11-2018, 02:19 PM
What does the 80 to 84 4WD light look like?
I know you 80-84 owners have, generally, the same dash as us 70's owners. On our dash (at least the Quadratrac rigs) we have a light that says "E-Drive" on the right side when we select, well, E-Drive. I am assuming Jeep changed that to "4WD" in 1980? Right? If so, does anyone have a picture of one lit up?
Old 10-11-2018, 02:28 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
My '83 dash has both lights, with the e-drive on top and 4wd underneath. I had the NP208, so the e-drive light was never used. You can see from the wear patterns on the back of the board that there was never even a bulb in that spot.
aa
Anthony
Old 10-11-2018, 03:35 PM
NP229 in 84 did not have the switch installed that controls that light, though there is definitely a spot for the bulb.
It might have something to do with the disco 44 in front?
Later years had the switch.
1984 GW
360
Performer Cam
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 10-11-2018, 04:35 PM
Awesome! Thanks, guys.
How to: Fixing final edition flip-lid light up visors adzam General FSJ Tech 3 11-25-2012 10:29 AM
third brake light? Eric S. General FSJ Discussion 9 12-23-2011 04:16 PM
Charge light wire connection ? 1cdccop General FSJ Tech 0 12-26-2010 06:44 PM
Rhino grille fog light install w/pics Maryland Rick General FSJ Tech 27 10-14-2007 08:43 PM
Courtesy light and dome light TestTeam General FSJ Tech 10 06-01-2007 11:20 PM
