Diesel swap - I think I found my engine...
-99 XJ Limited.
-Member, FSJ Prissy Restoration AssociationTags: None
Yeah, that would be sweet...
Until you started having to replace injectors and the injection pump.
I work at a chevy dealership, and spend alot of time under the hood of Duramax trucks, tearing them down to replace injectors or pumps. Really expensive, too, if not under warrenty.
But hey, when it runs - it runs great!"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
