Old 10-17-2018, 07:20 AM
tarriverarms's Avatar
tarriverarms tarriverarms is offline
Floorpan patches
Anyone replaced floorpans?
Who has the best ones? Any tips, comments?
Need to replace the Driver Front. Looking for the one that has some of the roll up to the firewall. Hopefully I won't need the roll but I won't know till i pull out the seam seal.
Old 10-17-2018, 07:59 AM
Full Size Jeeper's Avatar
classic2current is the company I used, but they all look the same to me.
1978 Wagoneer
Mods:
Old 10-17-2018, 08:01 AM
1978 Wagoneer
Mods:
Old 10-17-2018, 08:03 AM
1978 Wagoneer
Mods:
Old 10-25-2018, 02:10 AM
axton36 axton36 is offline
I know others got their pans at bjsoffroad.
Old 10-25-2018, 07:02 AM
itselliot's Avatar
panels
https://www.noramstore.com/c-1424069...1972-1988.html
hpschrot@hotmail.com
616 four 03 44 0 five
Old 10-25-2018, 09:46 AM
Kaiserjeeps's Avatar
If you have the floor mounted gas pedal, make sure the area it mounts in is very flat. The floor pans I used were not formed correctly in this area. I had to spend a couple hours pounding on a sand bag to stretch the metal down and them smooth it out for the pedal to stand upright. With out these changes the pedal leaned over and pointed at the steering column. If you have the firewall mounted gas pedal like Full Size Jeepers up above here, you are set. His floor pan looks good for this if he had the other style gas pedal. Just a heads up on this one. Good luck and post up so we too can enjoy the improvements.
Am I done yet?
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1953 Willy's wagon
1983 FJ60 wagon
We drove her tonight, laid down two dark patches of rubber! 1jeep4me General FSJ Discussion 13 10-28-2010 10:32 AM
Floorpan removal/install w/pics tkiller13 General FSJ Discussion 6 01-13-2009 01:34 PM
How to quickly remove floorpan from junkyard wag chrisnsarah General FSJ Tech 11 11-12-2008 09:47 PM
anybody make floorpan replacments? sandmanb Body 21 08-07-2002 01:58 PM
Floorpan replacement badaboom General FSJ Tech 2 06-29-2002 10:53 PM
