Old 10-16-2018, 05:46 AM
cosworth cosworth is offline
Early Gladiator Radiator
My trucks original radiator blew a core over the weekend. I'm looking at Champion radiator CC441 but the year listing on the unit is for 71-79.
Can anyone tell me dimension and mounting flange wise is it drop in for the early radiator? Outlets do not matter because my truck has a LSX swap so I have to move the lower outlet anyways.
I would fix my original but its already been patched at three times now and I'd rather just replace it at this point.
My truck is a 1969 J3800 originally had the Buick 350
Old 10-16-2018, 03:23 PM
Mikel's Avatar
Mikel Mikel is offline
PM Kaiserman. I believe he has one.
1969 M715 6x6
1963 J300 Swivel frame
Old 10-17-2018, 09:47 AM
'71-79 is for the 360 engine. IIRC '80-on is the same except for the overflow outlet direction.
There are purpose-made radiators for the SBC swap available from BJ's and likely from other places. http://www.bjsoffroad.com/Radiators_c_56.html I don't know if the core support for the 350 has the same radiator width as the later 360 core support, but it likely does. The 6-cylinder wagons have a narrower radiator (left to right), but I expect the V8s are all the same in this dimension.
Why don't you measure the core support yourself and compare to the radiator specs? Measure and post the numbers here. I would be happy to take a tape to my J-truck and see if the bay in the core support is the same size.
Or, you could use those measurements and buy a hot rod radiator that's the right size from somewhere like Summit Racing. https://www.summitracing.com/search/part-type/radiators/universal/yes?N=4294949245%2B4294951518&SortBy=Default&SortO rder=Ascending Then you will get a choice of outlet locations too.
Old 10-18-2018, 07:06 AM
The radiator shop that moved the outlet on the original for me wants to look at it before I just junk it so ill let them do so...
Honestly I was just being a bit lazy with no measuring and hoping it would be a easy yes or no if they were the same. No big deal though i'll get it pulled out and take some measurements.
Thanks for the reply's!
early or late '79??? jraynolds General FSJ Discussion 8 05-19-2015 09:10 PM
old dash swap (76 out, early style in) bmax65 General FSJ Discussion 11 06-22-2014 05:35 AM
TH400 early soft shifts and low line pressures Overkill SC General FSJ Tech 15 05-30-2013 01:31 AM
early vs late model heads... dlowrance General FSJ Tech 10 06-14-2010 06:57 AM
Early Steering Wheel Adapter Availability uglyjeep General FSJ Tech 3 03-23-2010 10:09 AM
