Old 10-14-2018, 06:26 PM
Coondawg Coondawg is offline
Tailgate window switch- No movement
So i just installed BJs tailgate window switch, but I'm having an issue that I can't figure out. It seems to be a motor grounding issue.
I know for sure the motor is good, working both ways. I was using a direct battery connection to get it up/down for disassembly.
I've got 12v coming from the switch in both directions, confirmed at the motor pigtail. But no motor movement. However, if I operate the switch down, and I apply a ground directly to the opposite pin on the pigtail, I get movement.
What gives? Motor seems to be grounded, confirmed continuity between the housing and the tailgate.
Old 10-14-2018, 06:57 PM
sounds like issue w/ safety switch
try bypassing it and see if things work normally
1994 Caprice wagon
Old 10-14-2018, 07:39 PM
Sorry, I forgot to mention the safety switch is completely out of the loop
Old 10-15-2018, 04:13 PM
It just seems like in overlooking a ground somewhere. Would a bad front switch cause this? If I take and group so the tan/brown wires at the dash switch, rear switch operates as normal.
Old 10-15-2018, 05:36 PM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
Yes as the whole thing grounds through the front switch. Does it work with the front switch?
1983 Cherokee Laredo. 360/ 727/ np229/ Rochester quadrajet/ Msd ignition
Dash Tailgate Window Switch johnsonic General FSJ Tech 3 02-08-2018 10:15 PM
Tailgate window trouble in '91 GW jpcoutts General FSJ Discussion 6 05-26-2007 07:46 AM
rear window switch diagnosis..help. rickauf General FSJ Tech 0 04-16-2007 09:44 AM
Tailgate window switch tanggod General FSJ Tech 3 09-19-2005 09:52 AM
$5 Tailgate Window Switch DLyons General FSJ Tech 2 10-12-2000 11:02 AM
