Old 09-27-2018, 12:23 PM
Rusty76 Rusty76 is offline
? about 76 Transfer Case rebuild
Hello:
First thanks for the help. I’m planning to rebuild
my QT to match my soon to receive new rebuilt 360 and TH400 (bought kit, just starting)
I was able to find lots of rebuild kits for the TH400 but none for the
QT. Does a guy just crack it open and replace piece by piece of what needs
replacing?
I really should start. Build thread.
Thanks!
Old 09-27-2018, 12:39 PM
Originally Posted by Rusty76
Hello:
replacing?
Thanks!
Have you read the TSM? http://oljeep.com/edge_76_tsm.html That would be the place to start. Jubilee Jeeps has a page you should read. http://jubileejeeps.org/quadratrac/index.htm
Not much parts support for these cases. I recall chains are available, but not cheap. Some bearings, seals, gaskets. Most everything else is not, except as acceptable used pieces.
Old 09-27-2018, 01:03 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
BJs actually has a pretty good assortment of parts availability now. Check over at FSJnetwork, lots of QT talk over there as well.
aa
Anthony
Old 09-27-2018, 01:46 PM
Ok great. Thanks for directing me towards the right info.
Old 09-27-2018, 07:29 PM
That’s some great info. Looks like all I really need is the kit and chain from BJ’s
Thanks Again
Old 09-29-2018, 02:02 PM
Something to consider: The QT case is full time 4WD (the first AWD). If that is cool with you, then continue down the path you are on. I am not sure where Cochrane is but if you don't need AWD all the time, you might consider converting over to a part time kit. I mention this because rebuilding the AWD can get expensive because of specific parts and tools needed. It is usually a bit cheaper to buy the part time kit that swaps the AWD parts out. Research "Mile Marker Part time kit quadratrac".
Also, keep your eyes open in the classifieds here, these cases pop up fairly often and it may be easier/cheaper to buy a complete case than rebuild yours. Same with Craigslist.
79 Cherokee Chief Wide Track, In pieces
Old 09-30-2018, 08:03 AM
Interesting. I looked at that part time kit pretty hard.
I
Old 09-30-2018, 09:11 AM
I live up in Western Canada. I just assumed keeping the complete AWD system would be the cheapest option. Now I
Old 09-30-2018, 11:49 AM
Cecil14's Avatar
If you get snow, the QT is a pretty awesome case. Rebuild it stock and you'll be happy. It may not be the absolute cheapest option, but you will be satisfied with its performance.
aa
Anthony
Old 09-30-2018, 12:48 PM
Oh, yeah. If you're in Canada, build it stock.
Old 10-01-2018, 03:07 PM
Originally Posted by Cecil14
If you get snow, the QT is a pretty awesome case. ...
Yep.
Old 10-02-2018, 08:30 AM
Done deal will keep it stock. Yes lots of snow. 6 inches overnight.
Wish wagon was on the road.
Thanks
Old 10-07-2018, 09:46 AM
Hi. I just moved the jubileejeeps.org web site to a new host provider this past week. If you had trouble accessing the QT pages, they were affected and thus down for a day or two. It should all be working now.
The QT is hard to find most parts. Stuff still available if you seek: bearings, fork pads, fiber thrust washer on main sprocket, vacuum diaphragm for Edrive shifter, Edrive lamp switch, seals and gaskets, chain, and fluid (TCL1).
BJs has new Brake Cones made by Novak. I got two sets and one set has been installed in a QT but it is not in a Jeep yet. One drawback to getting new brake cones has to do with the differential case sprocket. This sprocket can not be found new. Once a set of brake cones have been ground into the sprocket, chances are the sprocket is ruined. This is very common. I went through 16 differentials this summer to find 2 good case sprockets to put the new brake cones in.
It sounds like your QT is not in a Jeep right now. If so, that's good. Before ordering any parts, I recommend you tear the QT down and inspect it for wear and/or broken parts.
I have the 77 QT manual available here:
http://jubileejeeps.org/quadratrac/77jeep_qt_tsm.pdf
Good Luck!
Old 10-08-2018, 07:34 AM
Very helpful thank you. Here
Old 10-08-2018, 07:37 AM
Here is hoping my sprocket is in good shape.
Stuck doing brakes on DD this weekend. Maintenance on DD not nearly as fun as working the Wag that hasn
Old 10-08-2018, 09:25 AM
So what you're saying is Novak needs to get on making case sprokets as well?
-Jonny B.
1979 Cherokee Golden Eagle - 4" lift, 33x12.5x15
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 10-08-2018, 10:52 AM
I have had some words with Novak about this. I was told they would look into it back in May. I can't reference the email because all my old mail went away with the previous hosting company.
I encourage people to contact BJs Offroad and Novak about this.
https://bjsoffroad-com.3dcartstores....tion=contactus
https://www.novak-adapt.com/contact/
Thanks
Old 10-08-2018, 12:10 PM
Thanks
I'll get on it. I would honestly swap back to a QT case if more parts were readily available.
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
1984 J10 - Parts
Installation of Engine Transmission and Transfer Case? eps_jeeps General FSJ Tech 20 03-09-2013 03:13 PM
1980 J10 Transfer Case Questions 91blaze General FSJ Tech 30 08-19-2012 11:56 AM
transfer case shifter in J-20 soxcloud General FSJ Tech 5 04-21-2008 10:53 AM
transfer case rebuild Zorm General FSJ Tech 0 02-09-2006 07:57 AM
Transfer Case cracked driving to work today vistalite General FSJ Tech 5 04-21-2005 09:54 AM
