Old 10-23-2019, 06:29 PM
Rusty76 Rusty76 is offline
Do I need to replace fuel lines?
As of tomorrow I'm hoping that Engine, trans, transfer case will be installed
in my 76 Wagoneer. Moving on to the fuel system. The plan is to eventually EFI it but for now I picked up a cheap carb on amazon.
Wondering about fuel lines. Is it standard fair to replace all the lines from the tank to the engine? Rookie build questions constantly running through my head.
Thanks
Old 10-23-2019, 06:50 PM
fsj454 fsj454 is offline
Long time member
IF
If the fuel ⛽️ tank is out on the later model GW I always do Brake lines . And new rubber on hard fuel line . rUsty what side is your fuel line on ?
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 10-23-2019, 09:51 PM
Yes tank is out. Cant decided if I should buy a new one or get this one steamed out. My fuel lines run up the drivers side.
Old 10-24-2019, 02:12 PM
You should have steel lines running up the driver's frame rail, and short lengths of rubber to connect each section. No need to replace the steel lines unless they are damaged. I always replace fuel lines whenever I have them off. Get the Gates line from RockAuto or elsewhere - the cheap fuel line from the budget parts stores won't last. I usually buy it by the 10' length and keep it on hand. The fill hoses - up to you. I would decide based on condition.
In '76, you may have nylon vapor lines. I would keep those unless they are brittle and replace the rubber connecting sections as above.
Old 10-25-2019, 05:27 AM
Thats good news. Thanks guys. That will save a little time and money.
I will make a rockauto order.
Thanks
What size are the fuel lines/ no fuel delivery when hot? GW Fisherman General FSJ Tech 6 12-12-2011 06:58 AM
fuel pump stalling issues westcoastflea General FSJ Tech 8 07-21-2009 08:40 AM
more heat/carb questions waynestiles General FSJ Discussion 12 07-18-2008 08:03 AM
How many miles should it go? 82Laredo General FSJ Tech 9 01-20-2007 10:23 AM
