Old 02-03-2012, 11:51 PM
Zorm's Avatar
Zorm Zorm is offline
speedo cable mod?
building a 4.6 stroker engine with MPFI. Part of the wire harness is a speed sensor that on the newer little jeeps, screws into where the speeo cable would go on the old Jeeps. Well since I have the older, I need a sensor that will do both, speedo cable and electrical conn.
I could have bought one from Hesco, they are proud of theirs, so I decided I should be able to make my own. Bought the speed sencor for a 91 Wranger with a 4 cylinder, thats the only year I beleve that has the sensor and cable unit. So, the sensor will screw onto where the speedo cable goes, thing is, the threads on the other side are smaller in diamater then the speedo cable.
well after a few months of looking, I found a speedo cable for the sensor, screws onto the sensor but, the part that goes to the speedo, snaps on, I beleve in our Jeeps, it screws on righ?
so my thought, take off the part that screws on to the sensor, take the end off my speedo cable on the Jeep that screws onto the transfers case, and swap the two and find something recrimp everything back on.
can I do that??
83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
65 Corvair Corsa Convertible, 4 speed, 140 quad carb engine
71 F-250 Camper Special (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
Old 02-04-2012, 01:50 PM
CutterN55's Avatar
I'd be interested to see what you come up with. I'm driving by RPM's sice I put the 205 in. The Ford cable is not compatable with our guages.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 02-04-2012, 02:14 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
There is an aluminum screw on adapter for the mechanical/electric sensor. I didn't look too hard for one though. I used the end of an extra cable I had laying around that screws into the back of the speedometer. I used a drill bit just big enough to ream the crimp out so I could cram the cable housing back in and then recrimped it. Lubed the drive cable up and fished it back through.
Originally posted by Ristow
i bet it was Simon....
Quick Question 86 GW NP229 Speedo cable Disco - Selec Trac temps425 General FSJ Tech 2 05-26-2011 10:34 PM
transfer case swap speedo cable blues HorribleHarry General FSJ Tech 0 01-18-2008 05:09 PM
Ford 205 Speedo Cable for the Wag? McRoth General FSJ Tech 3 04-13-2007 01:58 PM
Need Speedo Cable Spec or where to buy blakeusa General FSJ Tech 1 10-07-2006 08:39 PM
Speedo Cable Lubeable? ClarkGriswald Drivetrain 0 08-15-2000 05:14 AM
