Old 11-21-2010, 11:48 AM
reece146's Avatar
reece146 reece146 is offline
Picture of FSJ parked next to WJ?
I've been researching Jeep wagons lately and I noticed that the WJ and FSJ share very similar exterior dimensions.
I don't believe what I'm reading but I've never seen one parked next to the other.
Does anyone have any images of these two Jeeps together?
The FSJ seems so much larger inside. Being slab sided has its benefits I guess.
Old 11-21-2010, 12:45 PM
suzq044's Avatar
suzq044 suzq044 is offline
Also due to the fact that it's mostly metal (the SJ). Very little in the way of padding and interior panels, and arm rests, and other plastic pieces that cover up lots of wiring for lots of sensors, etc. The plastic in the WJ takes up a LOT of space when all put together. You shell one of those, and you'll probably have about the same amount of interior space. You just won't be able to drive it. LOL
Max²: 1964 Jeep Panel Wagoneer
Planning Stages
2018 Wagoneer Rendering if you're interested.
Old 11-21-2010, 12:54 PM
Greeeeenberg's Avatar
Greeeeenberg Greeeeenberg is offline
Im not real familiar with FSJ numbers but here are the WJ numbers.
http://www.wjjeeps.com/dimensions.htm
Also im certain FSJ is longer.
'87 Grand Wagoneer - 360
'97 ZJ Orvis Edition - 318
Old 11-21-2010, 02:31 PM
reece146's Avatar
WJ
181.6 x 72.6 x 70.3
FSJ
186.4 x 74.8 x 66.4
Close enough as to not make much difference externally. The "bubbly" WJ looks so much smaller from the outside.
Old 11-22-2010, 10:31 AM
reece146's Avatar
186.4 x 74.8 x 66.4 : FSJ
181.6 x 72.6 x 70.3 : WJ
186.7 x 84.2 x 68.7 : WK
189.8 x 84.8 x 69.3 : WK2
austinaubinoe posted this image in the FSJ photo thread (WK2 next to a FSJ).
Still looks smaller in spite of the numbers - wondering if I should trust Wikipedia's numbers.
WJ next to a FSJ? Anyone?
Old 11-22-2010, 11:23 AM
austinaubinoe's Avatar
hey you used my picture
My sister actually has a WJ, so what kind of picture do you want? Does not have a front bumper at the moment, and has a 4" lift.........
Old 11-22-2010, 11:25 AM
reece146's Avatar
Just the same sort of pic... side by side to see how they compare is all I'm interested in.
Old 11-22-2010, 11:53 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
'04 WJ and '89 SJ They are very similar in size. But as mentioned before all the plastic and safety updates make it quite a bit smaller internally.
Originally posted by Ristow
i bet it was Simon....
Old 11-22-2010, 09:03 PM
iroc86 iroc86 is offline
I took these pictures last year. I thought they might come in handy someday.
Old 11-23-2010, 07:51 AM
reece146's Avatar
Awesome! Thanks!
(btw, still thinking about the full float axle things we exchanged emails about... direction more or less finalized... I'll probably send you an email at some point - lol)
Old 11-23-2010, 07:52 AM
reece146's Avatar
Great stuff, thanks!
Old 11-23-2010, 09:07 AM
Originally Posted by reece146
Awesome! Thanks!
Sounds good.
Old 11-23-2010, 11:45 AM
suzq044's Avatar
You know what's funny, the Patriot was actually pretty close in size to Levi; it's just not as wide, and not as tall.
unfortunately, I don't have the photo of it anymore.
Planning Stages
Old 11-23-2010, 01:12 PM
addicted's Avatar
Big Meanie
I can get a pic of a WJ, SJ and a Patriot together if anybody wants to see how they compare. Not that the Patriot is a real Jeep. But it is a pretty comfortable, roomy and fuel efficient front wheel drive car that has the same interior space as an XJ.
A proper introduction and a picture Hartman General FSJ Discussion 29 10-12-2010 04:44 PM
6 cyl throttle control linkage picture needed ccpanel General FSJ Tech 0 03-23-2010 10:55 AM
Need Picture - Edelbrock Carb Fuel Inlet Jayrodoh General FSJ Tech 0 11-01-2007 11:01 AM
Who has a picture of me from the 2003 ECI? Sycho15 General FSJ Discussion 0 05-21-2007 06:55 PM
GW Wheel Bearing, Spindle Bearing, Rotor Replacement - Information (Many Pictures) Kevin718 Drivetrain 20 09-24-2006 09:01 PM
