Old 08-14-2010, 06:14 PM
bigblock91
Posts: n/a
NOTHINGS HAPPENING!!!
ok can anyone out there tell me if there is a diagram for the connectoers under the dash? I'VE HAD THE STEERING COLOM OUT AND HAD ALOT OF THE PLUGS DISCONNECTED ... nothings happening when i turn the key... there are a few plugs un hooked but i cant find where they go.. grrr
Old 08-14-2010, 06:20 PM
CutterN55's Avatar
remember to hook up the negative on the battery? just throwin that out there...
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 08-14-2010, 06:22 PM
bigblock91
Posts: n/a
lol yeah i did...
Old 08-14-2010, 06:23 PM
CutterN55's Avatar
Only said it because I've done it before...more than once.
ROMANS 12:1-2
'89 GW deceased
Old 08-14-2010, 06:27 PM
bigblock91
Posts: n/a
yup me too
Old 08-14-2010, 07:53 PM
HOOT's Avatar
HOOT HOOT is offline
I don't think it is abnormal to have a few connections hanging not hooked up. Or atleast it isn't for a J truck. none of mine have all the options a waggy has and I have connectors hanging loose going nowhere but the truck runs fine.
I think the only way to track this down would be to check each component in the system until fire is made. Did you by any chance knock the connection loose down low where the neutral safety switch is?
Do all your lights work?
A Technical Service Manual for the 91 year is your best friend for Jeep info. It will have the wiring diagrams also.
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 08-14-2010, 10:09 PM
bigblock91
Posts: n/a
ok i have all my lites.. however i do not have anything that is controlled by the key can any snap me a pic of the clips that connect under the dash? i.e. the ignition switch specificly?
Old 08-15-2010, 02:53 AM
hkjensli hkjensli is offline
Here's the ignition wiring diagram for a 90, should be quite similar for 91. http://oljeep.com/gw/elec/90_numeric...-8W_Page-6.jpg
1991 GW 4bbl Edelbrock intake, carb & MSD ignition (wrecked)1988 GW bone stock (donor)(Under Recovery)
Drive safe Drive a FSJ!
Henning Kjensli
Old 08-15-2010, 10:12 AM
DAHoyle's Avatar
DAHoyle DAHoyle is offline
Well, fi everything is working, except items that are energized by the key, I would take a close look at your column install, specifically ensuring that the connectors are properly locked together, etc. I would also have a look at the linkage which connects the key cylinder to the actual switch. Chances are, that your problems are going to be related to the actual work you did(removing and replacing column).
67 M715
Strange Happening....brakes Billygoat General FSJ Tech 8 04-14-2009 10:17 AM
whats Happening to this thing??? wncwheeler General FSJ Discussion 6 05-07-2008 12:06 AM
Is this far from happening? ohioj20 General FSJ Tech 9 04-01-2007 10:26 PM
Any thing happening in my area? Temple Events 1 06-24-2005 10:32 PM
