Old 08-08-2010, 08:29 AM
89wagdrvr 89wagdrvr is offline
Noob tailgate window?
Hi guys. New here. I read the tech articles on the tailgate window motor issue but still have some questions. The window is stuck in the down position. I pulled the switch and cleaned it. Still no luck. The defroster is also not working. I read that the defroster is some how tied i with the tailgate window. Is there a fuse I should be looking for? Where should i start the search? Are there any write ups with pics of tailgate motor fix? Thanks. Its also a 1988 grand wagoneer.
Old 08-08-2010, 10:24 AM
Etcetera Etcetera is offline
On mine it didn't work because the safety switch was bad. I bypassed it. It's on the drivers side of the tailgate near the latch.
Eric
La Habra, CA
75 Wagoneer
Old 08-08-2010, 05:09 PM
No luck on the safety switch. I jumped the switch and still no movement. Any other ideas?
Old 08-08-2010, 05:54 PM
hkjensli hkjensli is offline
I'd check the switch in the tailgate itself, you pulled the dash switch correct? The dash switch is wired through the tailgate switch, and when it corrodes you may end up with none of them working (happened to me!) There's a good write up of how to fix this switch here: http://www.ifsja.org/forums/vb/showt...ailgate+switch
Also check the condition of the wires where they run into the tailgate, its a common spot for them to break
Good luck!
1991 GW 4bbl Edelbrock intake, carb & MSD ignition (wrecked)1988 GW bone stock (donor)(Under Recovery)
Drive safe Drive a FSJ!
Henning Kjensli
Old 08-09-2010, 06:05 AM
The wires running into tailgate look to be in very condition. I traced the wires back and can't find any problems. Is there any way to jump the tailgate key switch without taking the window out?
Old 08-09-2010, 08:06 AM
I wish there was, just did my switch 2 weeks ago. you'll have to remove the window and lifting mechanism to access the switch. Probably elementary but did you measure to see if you have voltage across the two wires goint into the motor when you press either switch? If you do the motor is shot.
Henning Kjensli
Old 08-09-2010, 09:32 AM
Use a multi-meter and make sure you have 12 volts at the gate. If not the key switch won't work.
There are some wiring diagrams at http://oljeep.com/gw/elec/GW_wiring.html
Same with the dash switch, I think it's the center wire needs to have 12v when the key is on or in acc.
On my 75 the tailgate runs through a breaker not a fuse. Not sure about the 88, I know quite a bit of the wiring is different. If you are not getting 12v at the center of the switch then maybe try swapping that breaker for a fuse temporarily.
Eric
La Habra, CA
75 Wagoneer
Old 08-09-2010, 02:05 PM
Ok thanks for the help. I bypassed the tailgate switch and got it working. What a pain in the arse that was. Seems like a crappy design.
Tailgate window trouble in '91 GW jpcoutts General FSJ Discussion 6 05-26-2007 07:46 AM
electrical issues tailgate window westcoastflea General FSJ Tech 1 06-21-2006 06:06 PM
Washers for tailgate window regulator Matthew W. Woodruff General FSJ Tech 1 06-29-2003 01:01 PM
tailgate weather strip, rear wiper, "keep window up while driving" GED General FSJ Tech 3 07-28-2002 03:29 PM
Rear Window a Sticken JERRY88GW Body 0 08-02-2000 03:52 AM
