Where can I get a speedo cable 70" for a 71 J4000 w/ Dana 20...and TH400. The connection at both ends are round - a little large at the trans and it's a standard solid speedo cable inside. Also cable was burned by exhust manifold and failed. Either a routing problem or cheap cable. Or maybe should be 80" and thats why it was routed too close to the manifold.
Thanks !
Thanks !
