ok all I am planning on installing a 4l80e and vortec 350 this summer. Here is what I plan to do. If I omit anything or miss any steps please let me know. (Seconldy many of you mention getting measurements off of the existing drivetrain to help with placement of the old drivetrain. what measurments do I need and what do I use them for?
1. Remove old drivetrain.
2. connect new engine and trans and transfer case.
3. place the complete drivetrain in the engine/trans bay for transmission crossmember fitting and for engine mount placement/fitting.
4. install new engine mounts and crossmember and install drivetrain.
5. Wire in new engine to existing wiring and place acessories on engine etc. reroute fuel lines etc.
Well that is what I plan to do in a nutshell. any tips will be much appreciated.
P.S. When I install the new drivetrain I will be checking to make sure that it stays even with the frame and secondly that all components clear items that are in the jeep. manifolds clear heater core etc. and that trans and transfer case components have room to operate. I know that the engine needs to be level side to side. also I realize that the rear driveshafts cannot
be angle too sharply. other than that is their anything else that I might need to consider?
Please help any tips will be greatly appreciated as I dont want to screw this up and have to fix it again later.
