Ok, so, leaving from Las Vegas to Bryce Canyon via Zion Nat. Park this morning didn't quite work out as planned. The trip from home to Vegas was uneventful. Today, however, sucked. When we were travelling through the edge of Arizona and through the deserts of Utah, the Jeep started sputtering, loosing power, and backfiring.
At first I thought maybe we just got some bad fuel in Vegas, so we stopped in St. George at a Checkers and I replaced the fuel filter. I also thought that maybe the fuel pump wasn't putting out enough pressure - and I have a Howell TBI, mind you, and nobody carried the 14psi inline pump that it uses. Plus, this is Utah, so to find somebody open is a miracle. But, I gave the filter a try.
It got really bad going into a little town called Hurricane, to the point that we could only go 40 up the easy mountains. We stopped at another Checkers, and so far the counter people have been very helpful, even if they don't have what we need. After at least 1/2 hour trying to find a fuel pump that would work, I mentioned just putting a carb back on just to make it. Then he asked if my distributor was part of the system or not. Well, no, but then it hit me - the ignition module!
Of course, they didn't have one, but through the miracle of the internet we found one at the Autozone back in St. George. So, back we went, sputtering all the way. We got there and were able to test the module, and it failed twice. So, I bought one and put it on. I also met . . . um, shoot, I forgot his real name, but he is Maynard on this list. It's amazing who you meet on the road.
After fixing that, we decided to just forget Zion and Bryce and go to Cedar City and see how things went. It went great, for about 20 miles. Then, on a steep uphill grade, the more I pushed the pedal, the less power I got. Finally we came to a stop. I think I may have figured it out - clogged catalytic converter. I banged on it and it rattled. There on the side of the freeway in 106 degree heat, I started punching holes in the cat.
Now we are in Cedar City at the KOA waiting for the muffler shop to open in the morning. Hopefully that will fix the problem.
If not, does anyone else have any ideas? The timing seems to be fine. It only happens when it starts getting hot, and I had a small exhaust leak that is suddenly much louder (before the holes in the cat.)
Mods: feel free to move this to tech if you feel it would fit better there.
