Old 05-16-2006, 11:01 AM
youngjeeper's Avatar
youngjeeper youngjeeper is offline
I've got seepage..
Rear dana44 always giving me troubles. Maybe it's the final straw and sign to step up. When I busted my passenger rear shaft the first time, it ruined the groove where the axle bearing and seal sit in. I have since replaced everything, and RTVed the hell out of that area. Worked for a good while, until I took it into a shop to get the electrac replaced..again. I had to re-seal with RTV once again and this time it did not work. The leak has worsened to the point of if I drive 200 miles, there is no more lube. After the last tellico trip both sides are seeping lube, after I re-sealed both sides for the 3rd time. Any suggestions?
88' GW Stock & Mint
77' CJ-7
http://gfsj.org/forums
Choptop/Crew Cab Build-up
http://www.ifsja.org/forums/vb/showthread.php?t=93389
Old 05-16-2006, 11:28 AM
rustywagoneers_com's Avatar
rustywagoneers_com rustywagoneers_com is offline
new housing
convert to full-float kit on D44 (might seal in slightly different areas for you)
or,
big axle time
inho
peace
Dave
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
Old 05-16-2006, 11:30 AM
boss6021's Avatar
boss6021 boss6021 is offline
You might try some cork gasket sheets, and custom make a gasket and use RTV to seal it. Some pics might help. The other thing that comes to mind is torque specs on the bolts and pattern. If indeed you are overloading the axles i would certainly go bigger.
Mike
\'79 Cherokee Chief S
Old 05-16-2006, 01:13 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Check and see if you can install inner seals. Some of the housings were machined to accept inner seals but not used. These seals will go in the axle tube itself. You would then have to pack the wheelbearings with Grease as you do the front.
Old 05-16-2006, 01:15 PM
Merc69's Avatar
Merc69 Merc69 is offline
Hit the junk yards and find a Dana 70, 14 Bolt etc. Time to step up or just keep pouring money into that black hole.
Old 05-16-2006, 01:36 PM
Stuka's Avatar
Stuka Stuka is offline
Dont use RTV. RTV dries hard and will let leaks seep through. High Tack or the like will work a whole lot better, and it doesnt ever dry, its stays 'wet' so new holes wont show up.
But with as many troubles as you have had with your rear axle breaking, I would say a bigger axle is in order.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 05-16-2006, 02:19 PM
rockjeep44's Avatar
The Advisor
Why are you even asking? BIGGER AXLES!
Buggy Buildup
Originally Posted by welchct
Old 05-16-2006, 04:25 PM
That is what I intially had first time around, but then switched to the other seals because they would not sit back in that groove anymore from the damage
88' GW Stock & Mint
77' CJ-7
Old 05-16-2006, 04:26 PM
Will give it a go!
88' GW Stock & Mint
77' CJ-7
Old 05-16-2006, 04:30 PM
Funds aren't flowing enough right now to get a 60, so a few bucks to try new sealing methods will work right now. Keeping my eyes out for a 60 rear and 8-lug conversion stuff for the front, reasonably priced, though. Maybe a semi-float 6-lug 60 would be easier right now, as far as time and $$ (will not need conversion stuff for front axle and 8lug rims).
Other problem is I prolly can't find anyone stupid enough to purchase an axle with an electrac in it.
88' GW Stock & Mint
77' CJ-7
Old 05-16-2006, 05:15 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
14bolts are like $100 bucks.
Old 05-16-2006, 08:02 PM
Stuka's Avatar
Just ebay it, you could sell gravel on ebay and people would buy it :P
Old 05-17-2006, 01:57 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
I agree, you guys wouldnt believe how much used stuff that I have sold on ebay for more than I bought it for new...
Yep, they are cheap... I have seen several for $50 here....
And of course, there is that one that I saw on the shoulder of the highway 3 days ago.... By the time I got back to it with a truck, it was gone though...
Old 05-17-2006, 07:10 PM
shackwrrr's Avatar
the things that lay on the side of the highway i found a reman cummins turbo on the side of one once it was a HUGE semi turbo and was locked up
Jeepless
In to Turbo crap now
Old 05-17-2006, 08:27 PM
blt2krl's Avatar
blt2krl blt2krl is offline
Man I got worried when I read the title of the topic. Thought maybe you were going to need a shot or something.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 05-18-2006, 11:51 AM
Will Morris Will Morris is offline
Just as a heads up, saw in the Ouray thread that you're moving out to Utah. If you go full widths you'll have to use some kind of flares since you have to pass emissions AND safety inspection out here and most of the cops are not quite as friendly as the good ole boys back home. I know I have a Dana 60 rear with 4.10s in the barn back home though if you want it though. Also, prepare for rust. They love using salt out here and it gets everywhere, so if you like your Jeep being clean, wash it a lot during the winter.
I'm currently FSJless at the moment, but that'll be changing soon. Hopefully by next week. It'll be good to have another southern FSJer out here in the weirdest state in the union.
Take it easy,
Will
'78 Cherokee NT in GA
'79 J10 Golden Eagle in UT
Old 05-18-2006, 12:17 PM
Will, good to hear from you. Sent you a PM.
88' GW Stock & Mint
77' CJ-7
Old 05-18-2006, 01:20 PM
blt2krl's Avatar
Take it easy,
Will
Are you kidding me, you have been in Utah and you haven't gotten ahold of me.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 05-18-2006, 07:11 PM
Stuka's Avatar
They use salt in Utah?! WTF, I thought only the idiot eastern states used it?! We just use sand here.
Old 05-18-2006, 09:01 PM
Stuka, never underestimate the idiocy of the state of Utah, but then we are surrounded by the largest inland body of salt water on the continent and home to the salt flats, salt mines, etc. But yeah, it still sucks even though they mix it with sand. Atleast it's dry so they don't rot out with the blazing speed that they did back in Maine.
Paul, PMed ya.
Dan, PMed ya back. Sorry to hijack your thread buddy.
