Old 07-02-2004, 10:39 AM
orangecherokee's Avatar
What backspacing is everyone running with these? any pics or info would be greatly appreciated.
Old 07-02-2004, 01:19 PM
Will Morris Will Morris is offline
Nick, depends on what size rims. If people are running 15s they're running like 2.5"-2.75" and some still have to grind but the stockish rims would be more like 3.5"-4" in the 16" and up range. I'd say go for 16s or 17s since those seem to be the rim sizes of the future. Particularly 17s, but I'm sure they're pricey.
Will
'78 Cherokee NT in GA
'79 J10 Golden Eagle in UT
Old 07-02-2004, 02:06 PM
i think i'm gunning for 16.5" and i'll weld my own beadlocks on them.
Old 07-02-2004, 06:12 PM
I run 16x10's with 4.5" BS
Todd
www.ttsfabworks.com
Old 07-03-2004, 02:43 AM
Then make sure you get some with a safety bead because you can still blow the inner bead unless you run bead locks on both sides of the rim. Someone from pirate though welded a bead along the inside of a 16.5" rim though to add the safety beads. I imagine that it made the rims a little harder to balance, but you're going to be running 39.5" swampers so who cares.
Will
Old 07-03-2004, 03:03 AM
good call Will, i think to save me a few headaches i'll run the 16s
Old 07-03-2004, 03:17 AM
Glenn_tx Glenn_tx is offline
16x10's here w/ 4.5 I believe.
Glenn<br /><br />-I\'d rather be a fencepost in Texas than the king of Tennessee!
Old 07-04-2004, 05:58 AM
jeepzilla47's Avatar
jeepzilla47 jeepzilla47 is offline
get some rims like mine from www.usa6x6.com i run them with 37 boggers and no weights. its a little shaky until they warm up...but after that, they barely shake. the rims are awesome, and must be true b/c of the ride.
Mike Hildreth...aka Tubby
"From nothing we have risen, and from nothing, we still rise!!" (Hatebreed)
84 GW in progress
fuel injected 454/th400/203/205/hpd60/ff14b 4.88/welded/4wdb/dbl/39.5 iroks/gm springs/rb shackle flip/ hydraulic assist
Old 07-05-2004, 05:17 PM
Brad W.'s Avatar
Brad W. Brad W. is offline
i'm using 16.5" hummer wheels. these are double beadlock style and are actually a two piece wheel like the old dodge combat rims. you can mount tires without a tire machine... just unbolt the wheel and slip the tire on, then bolt it back together. I love the design, but they do have one downfall... they have a lot of backspacing (about 7" I think)...
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 07-06-2004, 12:21 AM
KYJ10 KYJ10 is offline
Im not sure what the differnece is between the J truck and chero, but I running the chevy rear springs. And shackle flip. With a 16x10 and a 3.75 or 4" BS(I forget which), I run about 1.5" from my springs. 38.5x15's. Im glad I didnt go with the 2.75" rims! I have never rubbed the spring and run them at about 6-8 psi.
Starting to miss the addiction!
